Hi everyone,
I am new to home assistant. Firstly thanks for every volunteer on this forum. Hopefully somone can point me to the right direction.
I have two questions:
- I am have issue with setup of component asuswrt (both password and public key) in docker on centos 7.6. But I am able to do it in virtualenvironment HA instance. There is a little bit of HA version difference. Router is DSL-ac68u with merlin firmware which do not support telnet login anymore. Please see detail below. asuswrt.yaml are the same BTW.
Docker HA detail:
System Health
arch x86_64
dev false
docker true
hassio false
os_name Linux
python_version 3.7.3
timezone Australia/Sydney
version 0.94.1
virtualenv false
Lovelace
mode auto-gen
asuswrt.yaml
asuswrt:
host: 192.168.1.1
username: !secret router_username
password: !secret router_password
#ssh_key: /config/id_rsa
sensors:
- upload
- download
- upload_speed
- download_speed
error log
2019-06-20 10:00:50 INFO (MainThread) [homeassistant.setup] Setting up asuswrt 2019-06-20 10:00:50 ERROR (MainThread) [homeassistant.setup] Error during setup of component asuswrt Traceback (most recent call last): File “/usr/src/app/homeassistant/setup.py”, line 153, in _async_setup_component hass, processed_config) File “/usr/src/app/homeassistant/components/asuswrt/init.py”, line 55, in async_setup await api.connection.async_connect() File “/usr/local/lib/python3.7/site-packages/aioasuswrt/connection.py”, line 72, in async_connect self._client = await asyncssh.connect(self._host, **kwargs) File “/usr/local/lib/python3.7/site-packages/asyncssh/misc.py”, line 182, in await return (yield from self._coro) File “/usr/local/lib/python3.7/site-packages/asyncssh/connection.py”, line 5451, in connect conn, _ = yield from create_connection(None, host, port, **kwargs) File “/usr/local/lib/python3.7/site-packages/asyncssh/connection.py”, line 5057, in create_connection client_username = getpass.getuser() File “/usr/local/lib/python3.7/getpass.py”, line 169, in getuser return pwd.getpwuid(os.getuid())[0] KeyError: ‘getpwuid(): uid not found: 1000’
both password and key got same error above in docker.
virtualenvironment HA detail:
I can only upload one screenshot.
both password and key authentication method works on HA on virtualenvironment with same asuswrt.yaml above.
- When I migrate from virtualenvironment to docker, I have to reconfigure webhook id on ifttt due to the new instance have a new webhook id. is there a way to use the same ifttt webhook id so that I don’t have to reconfigure ifttt every time?
Thanks in advance.
