I try to use the asuswrt component but fails.
I get this in the log file, I would really appreciate if someone can help!
Regards S
Error during setup of component asuswrt
File “/usr/local/lib/python3.7/site-packages/homeassistant/setup.py”, line 151, in _async_setup_component
hass, processed_config)
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/asuswrt/init.py”, line 48, in async_setup
conf = config[DOMAIN]
KeyError: ‘asuswrt’
#This file I created empty and then it was populated automatically #perhaps when I tried to call the se “device_tracker.see” service #from development tools - here I used “mac”: “adress” attribute without success
01_23_45_67_89_AB:
hide_if_away: false
icon:
mac: 01:23:45:67:89:ab
name: 01 23 45 67 89 ab
picture:
track: true
did you add the main asuswrt component to your configuration.yaml, too?
you will then remove the login details from the configuration of the device_tracker that you posted above. the only thing you should end up with in the device tracker is:
