Error during setup of component pilight
I’m using hassbian. pilight seems to be working ok. But when I try to use the HA component it fails to initialise. The error log is a bit over my head. What’s wrong?
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 145, in _async_setup_component
component.setup, hass, processed_config)
  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/pilight.py", line 65, in setup
pilight_client = pilight.Client(host=host, port=port)
  File "/srv/homeassistant/lib/python3.5/site-packages/pilight/pilight.py", line 93, in __init__
answer_1 = json.loads(self.receive_socket.recv(1024).decode())
  File "/usr/lib/python3.5/json/__init__.py", line 319, in loads
return _default_decoder.decode(s)
  File "/usr/lib/python3.5/json/decoder.py", line 339, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/lib/python3.5/json/decoder.py", line 357, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
Never mind. It was due to me messing up the pilight installation. working now.
I have the same error message, what was the problem in your pilight installation.
many thanks.
