I recently wiped my config and setup HA again. All works fine except TelldusLive integration. I used my old conifguration files because they contain my config I want to use. Still with this valid config I’m getting below errors (this exact config worked fine in 0.60)
More info on component
Below is the configuration.yaml I’m using:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: .
longitude: .
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation:
# metric/imperial
unit_system:
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: /
# Custom Device Names/hidden/states etc. #
customize: !include customize.yaml
# TelldusLive Integration #
tellduslive:
# Enables the frontend/webgui
frontend:
# Enables logging
logger:
default: info
# Purge logging
recorder:
purge_interval: 5
purge_keep_days: 3
# Enables configuration UI
config:
http:
# Uncomment this to add a password (recommended!)
api_password:
# Uncomment this if you are using SSL or running in Docker etc
# base_url: example.duckdns.org:8123
# Checks for available updates
updater:
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
logbook:
# Track the sun
sun:
# Notify
notify:
- name:
platform:
api_key:
# Sensors
sensor: !include sensors.yaml
hue:
bridges:
- host:
# Alarm_clock & LedStrip Control #
input_number:
alarm_clock_hour:
initial: 6
min: 0
max: 23
step: 1
alarm_clock_minute:
initial: 15
min: 0
max: 55
step: 5
led_strip_1_animspeed:
name: LedStrip_1 animation speed
initial: 150
min: 1
max: 150
step: 10
input_boolean:
alarm_clock_status:
initial: on
# MQTT #
mqtt:
broker:
port: 1883
client_id:
username:
password:
# MediaPlayers #
media_player:
- platform: kodi
host:
name: OpenElec - KODI
- platform: cast
- platform: denonavr
host:
# Includes #
group: !include groups.yaml
scene: !include scenes.yaml
script: !include scripts.yaml
light: !include light.yaml`
On startup it fails to load some componenents.
I’ve tried having it disabled and it still produces the same error. I never get the GUI-box to appear where I can setup the integration. (it works in a similar manner as setting up Philips Hue for the first time)
Below is the error message appearing in the log:
''2018-01-23 17:20:32 ERROR (MainThread) [homeassistant.setup] Error during setup of component tellduslive
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 199, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/tellduslive.py", line 71, in setup
from tellduslive import Session, supports_local_api
File "/srv/homeassistant/lib/python3.5/site-packages/tellduslive.py", line 9, in <module>
from requests_oauthlib import OAuth1Session
File "/srv/homeassistant/lib/python3.5/site-packages/requests_oauthlib/__init__.py", line 9, in <module>
if requests.__version__ < '2.0.0':
TypeError: unorderable types: module() < str()
2018-01-23 17:20:32 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_call_id=1972216848-9, service_data=notification_id=invalid_config, title=Invalid config, message=The following components and platforms could not be set up:
- [tellduslive](https://home-assistant.io/components/tellduslive/)
Please check your config., domain=persistent_notification, service=create>
2018-01-23 17:20:32 INFO (MainThread) [homeassistant.core] Bus:Handling <Event platform_discovered[L]: discovered=('192.168.1.28', 'TellstickZnetLiteV2', 'ACCA5401AF08', 'E369PHH6VF', '1.0.14'), service=tellstick>
2018-01-23 17:20:32 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=persistent_notification.invalid_config, new_state=<state persistent_notification.invalid_config=notifying; title=Invalid config, message=The following components and platforms could not be set up:
Please check your config. @ 2018-01-23T18:20:32.788803+01:00>>
I’d be very glad if someone can me sort this out.
Cheers!
