Error during setup of component usps
I had to rebuild my HA on RPi and trying to setup USPS sensor
I setup the following in configuration.yaml file:
    usps:
      username: !secret usps_username
      password: !secret usps_password
Every time I restart my RPi, I see the following error:
Capture
When I check log file, there is an error:
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 148, in _async_setup_component
    component.setup, hass, processed_config)
  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/usps.py", line 46, in setup
    import myusps
  File "/srv/homeassistant/lib/python3.5/site-packages/myusps/__init__.py", line 12, in <module>
    import requests_cache
  File "/srv/homeassistant/lib/python3.5/site-packages/requests_cache/__init__.py", line 28, in <module>
    from .core import(
  File "/srv/homeassistant/lib/python3.5/site-packages/requests_cache/core.py", line 21, in <module>
    ver = tuple(map(int, requests.__version__.split(".")))
AttributeError: module 'pip._vendor.requests.__version__' has no attribute 'split'
Can someone help?
just so you know the usps component has been broken for a few months. USPS changed their login authentication and the current component fails to login. Someone has made a workaround that uses the emails sent with the same info, but you have to load a custom python script.
I did not know, thank you.
