Hi I’m a newbie. I’m running home assistant in a Docker container (network: HOST), and zoneminder in another container (networw: bridge) on the same machine. Zoneminder is working fine, but I can`t add the integration.
log:
Logger: homeassistant.setup
Source: components/zoneminder/__init__.py:75
First occurred: 23:04:20 (1 occurrences)
Last logged: 23:04:20
Error during setup of component zoneminder
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 159, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/connection.py", line 61, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.8/socket.py", line 918, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -2] Name does not resolve
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 670, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 392, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.8/http/client.py", line 1255, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.8/http/client.py", line 1301, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.8/http/client.py", line 1250, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.8/http/client.py", line 1010, in _send_output
self.send(msg)
File "/usr/local/lib/python3.8/http/client.py", line 950, in send
self.connect()
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 187, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 171, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f613d144400>: Failed to establish a new connection: [Errno -2] Name does not resolve
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 726, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 446, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='http', port=80): Max retries exceeded with url: /zm/api/host/login.json (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f613d144400>: Failed to establish a new connection: [Errno -2] Name does not resolve'))
File "/usr/src/homeassistant/homeassistant/setup.py", line 213, in _async_setup_component
result = await task
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/zoneminder/__init__.py", line 75, in setup
success = zm_client.login() and success
File "/usr/local/lib/python3.8/site-packages/zoneminder/zm.py", line 46, in login
req = requests.post(urljoin(self._server_url, 'api/host/login.json'),
File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 119, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 530, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 643, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='http', port=80): Max retries exceeded with url: /zm/api/host/login.json (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f613d144400>: Failed to establish a new connection: [Errno -2] Name does not resolve'))
My config file:
zoneminder:
host: http://192.168.0.35:9080
path: /zm/
path_zms: /zm/cgi-bin/nph-zms
It’s all in my local network, so I`m not using authentication. I’ve tried without the port number and only adding the host setting.
ZMninja works ok in my PC and my android phone, so the API is working.
The DNS setting in the host is 1.1.1.1, 1.0.0.1
Thanks for your help.
