I tried to update from the UI but after pushing the “Update” button I received the error “Error: Unknown Error, see logs”. When I lookedIN the HA logs I saw this message.
20-03-20 20:43:56 ERROR (SyncWorker_9) [supervisor.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.107.3 → 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”).
20-03-20 20:43:56 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
I’ve tried a few things:
Rebooting the entire server
Checking Disk space, but the disk is 52% full
Executing the command ‘hassio su repair’
Still got the same error after these options.
Does anyone got an idea? Running Hassio on a Intel NUC with Ubuntu 18.x on it.
Same here, from 0.107.1 to 0.107.3
Hassio running on Ubuntu server 18.04.4 LTS ( docker ), os_version: 4.15.0-91-generic.
Hardware Intel i7 8550U, 16MB ram, 128Gb SSD industrial PC.
The link to the server file are not available, so i can’t check if the error ( 500 Internal Server Error on Apache or IIS web server ) are real…
so the first thing, at least for me, is find the cause… If i can’t get the IP from the DNS i can’t connect with the server so the authentication fail….
Someone have problem with user credential… Group docker
PS: i used the hassio-installer script to install my Home Assistant software:
I’ve tested from the HassIO command line. Internet en DNS both works fine.
I can ping the Google DNS 8.8.8.8 and I can ping a dutch news site nu.nl. So that error “500 Server Error: Internal Server Error” must got other reason.
Docker seems to be like a virtual machine with own virtual interfaces… Docker isolate the container from the OS… So if ping respond, on the OS is OK but the container use a different “network”…
I don’t remember… type exit or quit in the SSH terminal if you use them…
Thake a look to the links i have posted… like:
Thanks for that. I’ve been successfully trying a few docker diagnostic commands. Again not sure what they tell me yet
