I have followed the link below and my domain me.example.com now points to my Home Assistant login page. However I am now faced with another issue - the following error occurs when I enter my username and password in an attempt to log in.
https://eladnava.com/binding-nodejs-port-80-using-nginx/
It doesn’t mater if I try to log in locally or via my domain name.
WebSocket connection to ‘ws://192.168.0.9/api/websocket’ failed: Error during WebSocket handshake:
Unexpected response code: 400
Any help is appreciated.
nginx file
server {
listen 80;
server_name me.example.com;
location / {
proxy_set_header X-Forwarded-For $remote_addr;
proxy_set_header Host $http_host;
proxy_pass "http://127.0.0.1:8123";
http in configuration.yaml
http:
# For extra security set this to only accept connections on localhost if NGINX is on the same machine
# server_host: 127.0.0.1
# Update this line to be your domain
base_url: https://me.example.com
use_x_forwarded_for: true
# You must set the trusted proxy IP address so that Home Assistant will properly accept connections
# Set this to your NGINX machine IP, or localhost if hosted on the same machine.
trusted_proxies: 127.0.0.1
