The strangest thing is happening with one of my esp8266 12-F boards where it disconnects randomly (it is right beside the wifi router) and also throws some errors even when I disabled all the sensors connected to it:
The config
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_pw
fast_connect: true
power_save_mode: none
reboot_timeout: 0s
manual_ip:
static_ip: 192.168.0.179
gateway: 192.168.0.1
subnet: 255.255.255.0
dns1: 192.168.0.1
# Enable logging
logger:
level: VERY_VERBOSE
# Enable Home Assistant API
api:
ota:
# uart:
# rx_pin: GPIO3
# tx_pin: GPIO1
# baud_rate: 9600
#sensor:
# - platform: mhz19
# id: living_room_mhz19c
# co2:
# name: "Living Room CO2"
# temperature:
# name: "Living Room MH-Z19C Temperature"
# update_interval: 60s
# automatic_baseline_calibration: true
# - platform: dht
# pin: D7
# model: dht22
# temperature:
# name: "Living Room Temperature"
# filters:
# - offset: -2.3
# humidity:
# name: "Living Room Humidity"
# - platform: adc
# pin: A0
# name: "Living Room LUX"
# unit_of_measurement: lx
# filters:
# - lambda: |-
# return (x / 10000.0) * 20000000.0;
# binary_sensor:
# - platform: gpio
# pin: D5
# name: "Living Room PIR Sensor"
# device_class: motion
I tried setting the IP to static, no change, power_save_mode: none, the same, fast_connect: true, no change.
Funny thing is I have another of these boards with the same sensors and it is rock solid.
Tried multiple power supplies without any difference.
Anyone got any suggestions? What that error might be about?
