Error executing script. Unexpected error for call_service at pos 1: Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
Hello to everyone :smiley:
I’m trying to solve this problem but i can’t find a solution… :frowning:
I want to call a one script from automation but i have this error:
TestNotificaAlexa: Error executing script. Unexpected error for call_service at pos 1: Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
While executing automation automation.testnotificaalexa
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 285, in async_render
    return compiled.render(kwargs).strip()
  File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 1090, in render
    self.environment.handle_exception()
  File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 832, in handle_exception
    reraise(*rewrite_traceback_stack(source=source))
  File "/usr/local/lib/python3.8/site-packages/jinja2/_compat.py", line 28, in reraise
    raise value.with_traceback(tb)
  File "<template>", line 2, in top-level template code
  File "/usr/local/lib/python3.8/site-packages/jinja2/sandbox.py", line 407, in getattr
    value = getattr(obj, attribute)
jinja2.exceptions.UndefinedError: 'None' has no attribute 'attributes'
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 138, in async_prepare_call_from_config
    service_data.update(template.render_complex(config[conf], variables))
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 81, in render_complex
    return {
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 82, in <dictcomp>
    render_complex(key, variables): render_complex(item, variables)
    return {
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 86, in render_complex
    return value.async_render(variables)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 287, in async_render
    raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: UndefinedError: 'None' has no attribute 'attributes'
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 206, in _async_step
    await getattr(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 385, in _async_call_service_step
    domain, service, service_data = async_prepare_call_from_config(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 140, in async_prepare_call_from_config
    raise HomeAssistantError(f"Error rendering data template: {ex}") from ex
homeassistant.exceptions.HomeAssistantError: Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
The automation:
- id: '1601037095611'
  alias: TestNotificaAlexa
  description: ''
  trigger: []
  condition: []
  - data:
      entity_id: script.01notifiche_alexa_e_app
      variables:
        message: "Attenzione!!! ALLARME ATTIVATO!! Effettuata Chiamata a Forze Dell'Ordine...\
          \ Risposta OK... In Arrivo. Invio Immagini di Sicurezza a Centro di Controllo\
          \ Completato... Sistema di Sicurezza Attivato... Sensori Attivi Comunicati:\
          \   {% for state in states.binary_sensor -%}\n{% if state.state == 'on'\
          \ and state.entity_id not in states.group.noalarm.attributes.entity_id %}\n\
          \ {{ state.name }}\n {%- endif -%}\n {%- endfor -%}\n"
        title: ATTENZIONE!! Allarme Attivato!!
    service: script.turn_on
The script:
01notifiche_alexa_e_app:
  sequence:
  - service: media_player.volume_set
      entity_id: media_player.echo_dot_di_marco
      volume_level: 1
  - delay: 00:00:02
  - data_template:
        method: all
        type: announce
      title: '{{ title }}'
      message: '{{ message }}'
    service: notify.alexa_media_echo_dot_di_marco
  - delay: 1
  - data_template:
        type: push
      volume_level: 0.5
Can someone help me please?
Stefano
Hi Stefano,
Since when do you experience this issue?
‘data_template:’ is not supported anymore since 0.115, this should be ‘data:’ now.
In case this happens since the upgrade to 0.115.x, I’d fix that at first.
Thanks for your reply, so the correct way is this:
  sequence:
      volume_level: 1
  - delay: 00:00:02
  - data:
        method: all
        type: announce
  - delay: 1
  - data:
        type: push
      volume_level: 0.5
Is correct?
No, just one data. I’d say:
 - data:
      type: push
In one of my automations:
  - data:
      msgtext: Hi, the radio and the TV are on now, let me turn it off
    service: script.tv_message
Yaml
I will edit the yaml
You could edit it in the GUI and then switch to YAML view.
It might be of help with assuring the correct ident.
Edit: Since this was pointed as the solution, let me add the actual solution.
OK perfect!! :smiley: Thanks a lot
Happy I could help!
