On RPi 4 (Raspbian GNU/Linux 11 (bullseye)) :
sudo apt install rustc
And then
pip install --upgrade pip (if not already done)
pip install --upgrade homeassistant
It worked for me (be careful, it’s very long…)
And then
is this done with the pi login or where?
this does not work On RPi 4 (Raspbian GNU/Linux 11 (bullseye)) :
And then
I try to give step by step instructions never could figure out why people have to be so cryptic on the steps they used to make something work
if this works you can sudo apt install rustc as any user, but the pip stuff you have to do inside your home assistant virtual environment if you are a core guy
That’s what I thought but it didn’t work this why I asked
Anyone find a solution for the cryptography problem? I tried to follow the recommendations in this thread, but no luck. I reinstalled rust and also tried to follow the description in Installation — Cryptography 39.0.0.dev1 documentation but still get the same error message:
Building wheel for cryptography (pyproject.toml) did not run successfully…
The cargo build seems to start, but at the end it fails here:
Caused by:
process didn’t exit successfully:rustc --crate-name cryptography_rust --edition=2018 src/lib.rs --error-format=json --json=diagnostic-rendered-ansi --crate-type cdylib --emit=dep-info,link -C opt-level=3 -C lto=thin --crate-type cdylib -C overflow-checks=on --cfg 'feature="default"' --cfg 'feature="extension-module"' -C metadata=00452e0f91e94e19 --out-dir /tmp/pip-install-t8wcez__/cryptography_75eb470902364bbea01c68cdf899ec6c/src/rust/target/release/deps -L dependency=/tmp/pip-install-t8wcez__/cryptography_75eb470902364bbea01c68cdf899ec6c/src/rust/target/release/deps --extern asn1=/tmp/pip-install-t8wcez__/cryptography_75eb470902364bbea01c68cdf899ec6c/src/rust/target/release/deps/libasn1-542eab56166b85cc.rlib --extern chrono=/tmp/pip-install-t8wcez__/cryptography_75eb470902364bbea01c68cdf899ec6c/src/rust/target/release/deps/libchrono-07098687f402cd86.rlib --extern once_cell=/tmp/pip-install-t8wcez__/cryptography_75eb470902364bbea01c68cdf899ec6c/src/rust/target/release/deps/libonce_cell-2531e1844ca1f493.rlib --extern ouroboros=/tmp/pip-install-t8wcez__/cryptography_75eb470902364bbea01c68cdf899ec6c/src/rust/target/release/deps/libouroboros-f90c63d49e9f5ded.rlib --extern pem=/tmp/pip-install-t8wcez__/cryptography_75eb470902364bbea01c68cdf899ec6c/src/rust/target/release/deps/libpem-8cccd76f7bd027a3.rlib --extern pyo3=/tmp/pip-install-t8wcez__/cryptography_75eb470902364bbea01c68cdf899ec6c/src/rust/target/release/deps/libpyo3-6c7e61c8d5fbe332.rlib
(exit status: 101)
LLVM ERROR: Invalid abbrev number
error: could not compilecryptography-rust
I’m on Raspberry 3 with HA Core. Do not understand why I have to compile this lib at all, is there a version which can be downloaded somewhere?
I’m on Raspberry 3 with HA Core 2022.11.4
ERROR: Failed building wheel for cryptography
#install Rust
curl https://sh.rustup.rs -sSf | sh
sudo apt -y install rustc
pip3 install pyOpenSSL --upgrade
Thanks for the tip. Did the upgrade for pyOpenSSL
Successfully uninstalled pyOpenSSL-22.0.0
Successfully installed pyOpenSSL-22.1.0
But still the same error during upgrade of HA
Here is my HA environment reported from the build error
Python: 3.9.11
platform: Linux-5.10.103-v7±armv7l-with-glibc2.28
pip: n/a
setuptools: 65.6.0
setuptools_rust: 1.5.2
rustc: n/a
Error is still
error: could not compile `cryptography-rust
After that I’ve installed a new version of HA
source $HOME/.cargo/env
What a ride to do the update to 2022.11.4. Again, I learned a lot about the settings and which libraries are important. What did actually work and Raspberry 3 with HA Core
Switch to the HA environment
Then I executed the followint steps to make sure the update works correctly
After the reboot the initial start of the HA environment version 2022.11.4 created a lot of errors. E.g. MQTT integration did not work, many config files generated errors. I did a config file check (under Developer Tools) and it reported the following error:
Component error: mqtt - IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE! Importing the numpy C-extensions failed. This error can happen for many reasons, often due to issues with your setup or how NumPy was installed. We have compiled some common reasons and troubleshooting tips at: https://numpy.org/devdocs/user/troubleshooting-importerror.html Please note and check the following: * The Python version is: Python3.9 from "/srv/homeassistant/venv_3.9.11/bin/python3.9" * The NumPy version is: "1.23.5" and make sure that they are the versions you expect. Please carefully study the documentation linked above for further help. Original error was: /lib/arm-linux-gnueabihf/libm.so.6: version `GLIBC_2.29' not found (required by /srv/homeassistant/venv_3.9.11/lib/python3.9/site-packages/numpy/core/_multiarray_umath.cpython-39-arm-linux-gnueabihf.so)
So even I had updated the numpy lib something is still wrong. I used tips from here Installing Home Assistant Core on Raspberry Pi 3B+ step by step (2022.11.2) | and here System cannot restart after update to 2022.10.2 - #2 by pck to do the following:
At the end this worked, and the system comes back with all integrations, especially MQTT. Hope this helps others to succeed the Home Assistant Update adventures
this helped, and - in case someone has issues with rustup / rustc not being available, run the
as homeassistant user, exit the shell, e.g. exit and again login, check echo $PATH and confirm that homeassistant/.cargo/bin is on it and rustc --version gives some version back
