Hi
My log is full of errors like this but the strange thing is that the sensors still works.
furthermore its a scrape sensor not a rest? so I don’t get that part either.
I’ve defined 4 scrape sensors in a row that are trying to pull information on the same website, you see 2 of them below this page.
Could it be that these 4 requests to the same URL are too many at the moment?
Can I somewhere define different pull moments in time? Because I now lean on the scan_interval of HA.
Logger: homeassistant.components.rest.data
Bron: components/rest/data.py:120
integratie: RESTful ([documentatie](https://www.home-assistant.io/integrations/rest), [problemen](https://github.com/home-assistant/core/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+rest%22))
Eerst voorgekomen: 17 juli 2024 om 13:17:21 (2809 gebeurtenissen)
Laatst gelogd: 08:51:54
* Error fetching data: https://www.tradegate.de/orderbuch.php?isin=IE00BZCQB185" failed with Server disconnected without sending a response.
* Error fetching data: https://www.tradegate.de/orderbuch.php?isin=IE00BZCQB185" failed with peer closed connection without sending complete message body (incomplete chunked read)
my yaml:
scrape:
- resource: "https://www.tradegate.de/orderbuch.php?isin=IE00BZCQB185"
scan_interval: 300
- name: "test1"
unique_id: test1
select: ".longprice"
value_template: >-
{{ value.replace(',','.')|select('in','.-0123456789')|join }}
index: 0
scan_interval: 300
- name: "test2"
unique_id: test2
value_template: >-
index: 1
