Im getting the error and cant seem to figure it out.
Its preventing me from restarting.
Does anybody know what is causing it?
Sun Mar 17 2019 20:49:48 GMT-0400 (Eastern Daylight Time)
Error saving event: <Event call_service[L]: domain=switch, service=turn_on, service_data=entity_id=['switch.garage_door']>
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 1236, in _execute_context
cursor, statement, parameters, context
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/default.py", line 536, in do_execute
cursor.execute(statement, parameters)
sqlite3.DatabaseError: database disk image is malformed
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/recorder/__init__.py", line 298, in run
session.flush()
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/session.py", line 2446, in flush
self._flush(objects)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/session.py", line 2584, in _flush
transaction.rollback(_capture_exception=True)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/util/langhelpers.py", line 67, in __exit__
compat.reraise(exc_type, exc_value, exc_tb)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/util/compat.py", line 277, in reraise
raise value
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/session.py", line 2544, in _flush
flush_context.execute()
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/unitofwork.py", line 416, in execute
rec.execute(self)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/unitofwork.py", line 583, in execute
uow,
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/persistence.py", line 245, in save_obj
insert,
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/persistence.py", line 1116, in _emit_insert_statements
statement, params
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 980, in execute
return meth(self, multiparams, params)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/sql/elements.py", line 273, in _execute_on_connection
return connection._execute_clauseelement(self, multiparams, params)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 1099, in _execute_clauseelement
distilled_params,
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 1240, in _execute_context
e, statement, parameters, cursor, context
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 1458, in _handle_dbapi_exception
util.raise_from_cause(sqlalchemy_exception, exc_info)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/util/compat.py", line 296, in raise_from_cause
reraise(type(exception), exception, tb=exc_tb, cause=cause)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/util/compat.py", line 276, in reraise
raise value.with_traceback(tb)
sqlalchemy.exc.DatabaseError: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id) VALUES (?, ?, ?, ?, ?, ?, ?)'] [parameters: ('call_service', '{"domain": "switch", "service": "turn_on", "service_data": {"entity_id": ["switch.garage_door"]}}', 'LOCAL', '2019-03-17 23:46:16.261639', '2019-03-18 00:16:35.867032', '0c11a310cea142d183cb33bd5c2c13dc', None)] (Background on this error at: http://sqlalche.me/e/4xp6
