Anybody know what is causing this? When I use the check config I just keep getting a spinning arrow.
any advice I would appreciate it!
Sun May 27 2018 21:48:41 GMT-0400 (Eastern Daylight Time)
Error handling request
File “/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py”, line 381, in start
resp = await self._request_handler(request)
File “/usr/lib/python3.6/site-packages/aiohttp/web_app.py”, line 322, in _handle
resp = await handler(request)
File “/usr/lib/python3.6/site-packages/aiohttp/web_middlewares.py”, line 88, in impl
return await handler(request)
File “/usr/lib/python3.6/site-packages/homeassistant/components/http/static.py”, line 68, in staticresource_middleware
File “/usr/lib/python3.6/site-packages/homeassistant/components/http/real_ip.py”, line 27, in real_ip_middleware
File “/usr/lib/python3.6/site-packages/homeassistant/components/http/ban.py”, line 68, in ban_middleware
File “/usr/lib/python3.6/site-packages/homeassistant/components/http/auth.py”, line 28, in auth_middleware
File “/usr/lib/python3.6/site-packages/homeassistant/components/http/view.py”, line 104, in handle
result = await result
File “/usr/lib/python3.6/site-packages/homeassistant/components/config/core.py”, line 24, in post
errors = yield from async_check_ha_config_file(request.app[‘hass’])
File “/usr/lib/python3.6/site-packages/homeassistant/config.py”, line 690, in async_check_ha_config_file
check_ha_config_file, hass)
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/lib/python3.6/site-packages/homeassistant/scripts/check_config.py”, line 328, in check_ha_config_file
del core_config[CONF_PACKAGES]
KeyError: ‘packages’
