Hi there,
I am new to HA or better to say to ymal. I did create a automation based on the schedule integration to turn on/off a few xmas lights in and around the house using smart plugs (Zigbee mostly) and such.
I came up w/ the following automation in ymal (used the GUI to get a base setting and went from there). Editing happens inside HA automation via opton ‘Edit in YAML’
alias: Xmas Schedule for Light
description: "x"
triggers:
- trigger: state
entity_id:
- schedule.xmas_lights_inhouse
to: "on"
for:
hours: 0
minutes: 0
seconds: 2
- trigger: state
entity_id:
to: "off"
for:
hours: 0
minutes: 0
seconds: 2
conditions: []
actions:
- action:
- service: 'switch.turn_{{ trigger.to_state.state }}'
metadata: {}
data: {}
entity_id: switch.zigbee_3_0_stecker_ali_002
mode: single
That code produces:
Message malformed: value should be a string for dictionary value @ data['actions'][0]['action']
I seem not fot get my head around, I can’t see the forest for the trees I guess.
Sorry - if it is very obvious to the experienced eye but I am missing it.
Checking the forum did not help me out here.
Thanks for reading that far,
HANT
PS. Syntax check w/. yamllint.com did not find any issues
