Hi everybody,
I’m working on a Blueprint since yesterday and it is driving me nuts. Maybe it’s something ovious but I just don’t get it.
The Blueprint is for an automation which turns on a smoke alarm (an input_boolean helper) when a smoke detector detacts smoke and if nobody is present it also turns off the power in that certain area. There is also an option to have the smoke detector ‘silent’, so the automation only triggers if nobody is present (according to the state of an input_select helper).
The option to have the smoke detector silent can be checked through a boolean selector in the blueprint, which, according to the documentation, reports as true if checked or false if unchecked. So I used the boolean !input silent as the enabled: state of a condition, so the condition is only in effect when the boolean is checked.
The Blueprint works fine when I check the silent boolean, but if I have it unchecked I get the Error: Message malformed: Missing input silent_boolean
I do not understand why this is not working, the selector boolean apperently has no other options and the state false is a valid state for enabled: in a condition, what am I missing?
You can find the code of the Blueprint here:
blueprint:
description: Zuordnung der Rauchmelder zu Alarm und Abschaltung
domain: automation
author: gorgor_gonzales
input:
rauchmelder_input:
selector:
entity:
domain:
- binary_sensor
device_class: smoke
rauchmelder_ort:
name: Ort des Rauchmelder
selector:
text:
multiple: false
type: text
unterverteilung_output:
description: Die Unterverteilung die bei Feuer automatisch abgeschaltete werden soll
selector:
entity:
domain:
- switch
integration: shelly
multiple: true
silent_boolean:
name: Stumm wenn geöffnet?
description: Wenn ausgewählt alarmiert der Rauchmelder nur wenn der Laden geschlossen ist.
selector:
boolean:
mode: single
triggers:
- trigger: state
entity_id: !input rauchmelder_input
to: "on"
- trigger: event
event_type: mobile_app_notification_action
event_data:
action: verstanden
- trigger: state
to: "off"
id: Kein Rauch mehr Erkannt
conditions: []
actions:
- choose:
- conditions:
- condition: trigger
id:
- Rauch Erkannt
enabled: true
- condition: state
entity_id: input_select.klunkerkranich
state: geschlossen
enabled: !input silent_boolean
sequence:
- action: input_boolean.turn_on
metadata: {}
data: {}
entity_id: input_boolean.rauchalarm
- action: input_text.set_value
metadata: {}
value: !input rauchmelder_ort
entity_id: input_text.rauchmelder_alarm
- if:
- condition: state
state: geschlossen
then:
- action: switch.turn_off
entity_id: !input unterverteilung_output
metadata: {}
data: {}
- conditions:
id:
- Rauchalarm gelesen
- Kein Rauch mehr Erkannt
sequence:
- action: input_boolean.turn_off
metadata: {}
data: {}
enabled: true
Thank you for your help!
