Error in check config
Hi, I tried to check my config and found this error in log:
[21:59:59] ERROR: The configuration check did not pass!
[21:59:59] ERROR: See the output below for more details.
Testing configuration at /tmp/config
Fatal error while loading config: (idna 3.1 (/usr/local/lib/python3.8/site-packages), Requirement.parse(‘idna<3,>=2.5’), {‘requests’})
Failed config
General Errors:
- (idna 3.1 (/usr/local/lib/python3.8/site-packages), Requirement.parse(‘idna<3,>=2.5’), {‘requests’})
Failed config
General Errors:
Can someone please help me to fix it?
My setup:
Home Assistant OS 5.10
Home Assistant Core 2021.1.5
Is there anything else in the logs? To me it looks like it cant install idna but that should be none of you business. But from the current log I cant see what integration is causing this.
What language settings are you using?
my HA istance in in italian. There are a lot of error before it: here’s the full log.
 /usr/local/lib/python3.8/site-packages/google/api/http_pb2.py:96: DeprecationWarning: Call to deprecated create function Descriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _HTTPRULE = _descriptor.Descriptor(
/usr/local/lib/python3.8/site-packages/google/api/http_pb2.py:312: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _descriptor.FieldDescriptor(
/usr/local/lib/python3.8/site-packages/google/api/http_pb2.py:330: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/api/http_pb2.py:305: DeprecationWarning: Call to deprecated create function Descriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _CUSTOMHTTPPATTERN = _descriptor.Descriptor(
/usr/local/lib/python3.8/site-packages/google/api/annotations_pb2.py:34: DeprecationWarning: Call to deprecated create function FileDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  DESCRIPTOR = _descriptor.FileDescriptor(
/usr/local/lib/python3.8/site-packages/google/api/annotations_pb2.py:48: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  http = _descriptor.FieldDescriptor(
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:21: DeprecationWarning: Call to deprecated create function FileDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:40: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _descriptor.EnumValueDescriptor(
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:47: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:50: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:53: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:34: DeprecationWarning: Call to deprecated create function EnumDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _SSMLVOICEGENDER = _descriptor.EnumDescriptor(
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:71: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:78: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:81: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:84: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:65: DeprecationWarning: Call to deprecated create function EnumDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _AUDIOENCODING = _descriptor.EnumDescriptor(
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:113: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:106: DeprecationWarning: Call to deprecated create function Descriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _LISTVOICESREQUEST = _descriptor.Descriptor(
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:152: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:145: DeprecationWarning: Call to deprecated create function Descriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _LISTVOICESRESPONSE = _descriptor.Descriptor(
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:191: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:209: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:227: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:245: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:184: DeprecationWarning: Call to deprecated create function Descriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _VOICE = _descriptor.Descriptor(
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:284: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:302: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:320: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:277: DeprecationWarning: Call to deprecated create function Descriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _SYNTHESIZESPEECHREQUEST = _descriptor.Descriptor(
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:359: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:377: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:404: DeprecationWarning: Call to deprecated create function OneofDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _descriptor.OneofDescriptor(
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:352: DeprecationWarning: Call to deprecated create function Descriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _SYNTHESISINPUT = _descriptor.Descriptor(
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:424: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:442: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:460: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:417: DeprecationWarning: Call to deprecated create function Descriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _VOICESELECTIONPARAMS = _descriptor.Descriptor(
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:499: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:517: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:535: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/google/cloud/texttospeech_v1/proto/cloud_tts_pb2.py:553: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
[07:34:25] ERROR: The configuration check did not pass!
[07:34:25] ERROR: See the output below for more details.
Fatal error while loading config: (idna 3.1 (/usr/local/lib/python3.8/site-packages), Requirement.parse('idna<3,>=2.5'), {'requests'})
Failed config
  General Errors:
    - (idna 3.1 (/usr/local/lib/python3.8/site-packages), Requirement.parse('idna<3,>=2.5'), {'requests'})
Successful config (partial)
[07:34:25] INFO: The full output has been written to /share/check_config.txt
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
So there is a problem with texttospeech component. As a first try, disable it and see if goes away.
It was related to google cloud tts.
Strage: config is in line with the description. I commented it and the error is gone :slight_smile:
TY for your support!
