Jokerigno
(Jokerigno)
July 13, 2021, 9:55pm
1
I checked my config with Check Home Assistant configuration addon before moving from 2021.06 to 2021.07 but I see an error in log that fails the check
e[31mFatal error while loading config:e[0m module 'base64' has no attribute 'decodestring'
e[01;37mFailed confige[0m
e[01;31mGeneral Errors:e[0m e[31me[31m
- module 'base64' has no attribute 'decodestring'
Can anyone support here?
Not without more information on your configuration.
Any idea where you are using what it is complaining about?
Jokerigno
(Jokerigno)
July 13, 2021, 9:59pm
3
Sure. sorry.
Here’s my environment:
System Health
version
core-2021.6.6
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
virtualenv
false
python_version
3.8.9
os_name
Linux
os_version
5.10.45
arch
x86_64
timezone
Europe/Rome
Home Assistant Community Store
GitHub API
ok
Github API Calls Remaining
4998
Installed Version
1.13.2
Stage
running
Available Repositories
926
Installed Repositories
71
Home Assistant Cloud
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
Home Assistant Supervisor
host_os
Home Assistant OS 6.1
update_channel
stable
supervisor_version
supervisor-2021.06.8
docker_version
20.10.6
disk_total
38.7 GB
disk_used
18.4 GB
healthy
true
supported
true
board
ova
supervisor_api
ok
version_api
ok
installed_addons
Samba share (9.5.1), AppDaemon 4 (0.6.2), Check Home Assistant configuration (3.8.0), Assistant Relay (0.7.4), ESPHome (1.16.2), Log Viewer (0.11.0), Valetudo Mapper (1.9.0), SSH & Web Terminal (9.0.0), AirCast (3.1.1), OpenTTS it (2.0.0), Visual Studio Code (3.5.0)
Lovelace
dashboards
8
resources
41
views
16
mode
storage
Spotify
api_endpoint_reachable
ok
I checked for more info on the error but didn’t find any specific error related to HA.
decodestring is not in your configuration anywhere?
tom_l
July 14, 2021, 3:22am
5
The Check Home Assistant configuration addon has been producing false positives for the last umpteen updates. It’s basically useless.
Jokerigno
(Jokerigno)
July 14, 2021, 5:47am
6
There a valid alternative Tom? I know that I can restore a snapshot but I was wondering if there’s another way
tom_l
July 14, 2021, 6:29am
7
Read through he breaking changes in the release notes and make any required changes before updating.
Jokerigno
(Jokerigno)
July 15, 2021, 9:23pm
8
I read the changes and made the requirement (http for example).
I upgraded but now I cannot restart due to same error appeared in check config addon:
Fallita chiamata a servizio homeassistant/restart . module ‘base64’ has no attribute ‘decodestring’
@tom_l do you have any other tip?
EDIT: it was caused by a custom component.
Did you try raising an issue in their GitHub repo so that are aware?
Jokerigno
(Jokerigno)
July 16, 2021, 9:13am
10
No because I was running an old version and the latest one works as expected. Unfortunately this component is not on HACS.
I guess it is time to upgrade
Jokerigno
(Jokerigno)
July 16, 2021, 9:43am
12
Indeed. HACS was a big revolution and I stopped to manually search for updates. Unfortunately not every custom component is there at the moment.
I meant upgrade HA and/or the binding to use a newer version without the issue. The only other way might be to dive into the PRs to figure out how to revert whatever broke it for you.
Jokerigno
(Jokerigno)
July 16, 2021, 9:52am
14
Oh sorry but now the issue is gone.
I firstly upgraded the custom component and now 2021.07 is working and rebooting with no issue.
RoadkillUK
(Roadkill Uk)
August 6, 2021, 7:29am
15
What was the custom component please? I can’t upgrade from 2021.6.6
RoadkillUK
(Roadkill Uk)
August 6, 2021, 12:31pm
17
I have feedparser, I’ve just updated it and I’ll come back later when I have time (I’m on lunch) to upgrade.
RoadkillUK
(Roadkill Uk)
August 6, 2021, 6:10pm
18
Not the done thing to reply to your own posts, however, I must thank you @Jokerigno , you have provided me with information that fixed a problem that I have been struggling with for about 5 weeks.
Jokerigno
(Jokerigno)
August 6, 2021, 9:10pm
19
One is glad to be of service
