this is the project i am trying to build: Printables
i got everything wired up fine.
on the coding side, when i try to use his codes and i got errors all over the place config tung.txt - Google Drive
any idea what his testblind.yaml is or what’s in it?
I have updated the original as it was out of date. You will still have to make modifications for your stepper motor.
The main changes are
esphome:
platform: ESP8266
board: d1_mini
esp8266_restore_from_flash: True
on_boot:
to
esp8266:
board: d1_mini
esphome:
on_boot:
You’re also missing the encryption key, don’t forget to set it up in secrets.yaml; unless you just put your encryption key instead of !secret enc_key
api:
encryption:
key: !secret enc_key
and I don’t think you can use stepper as a stepper ID, change it back to mystepper
OK, try that then
@tung256 You are using an ESP32, try this instead
esp32:
board: nodemcu-32s
esphome:
on_boot:
The rest of the above reply still applies.
thank you for updating your code to work with the uln2003 driver. i compiled and no errors came up!
this is my file updated to work with the ESP32 and TMC2208 driver, i get a bunch of errors as seen here
Change id: my_stepper
to id: $mystepper
stepper:
- platform: a4988
See how that goes.
The information is in the error text.
thanks! error went away.
it refuses to connect to my wifi network, even though i disabled my 5ghz band. will try again tomorrow…
im happy to say it finally works!
used this whole code of yours as seen here. compiled to get the bin file. next, i flashed the board using this link i used the ESPHome flasher at Web - ESPHome
i dont know why my easyFlasher exe program does not work after days of troubleshooting.
one of the thing i noticed is that my Nema 17 is extremely slow. this is the value from the guy using the nema 17 motor
is there anyway to boost up the speed? if i use your code, would it boost the speed? im not sure if your code is compat with this nema 17.
the only reason i am using nema 17 is because the motor in your code is not powerful enough to lift my big heavy roller shade.
Yes It’s the variable/substitute for
max_speed:
See Docs
ok. thanks for confirming.
1 of the thing i noticed now is that if i unplug power, and plug back in, the memory is gone. meaning i have to run set up again. is there anyway to make it remember the position?
today, the shade was opened. i unplugged. plugged back in power. when i hit the close button, it closed but the motor would not stop when it reached the closed position.
all issues resolved thanks to @RoadkillUK !!!
i made this video so others know how to make one themselves a lot easier DIY your own automatic roller shade for big, or small windows - YouTube hope that helps.
looks like i need more torque for an even bigger roller shade.
can i use the same code of the nema 17 for the bigger Nema 23 motor? if not, which part of the esphome yml code must i change?
Yes, I can’t see why the same code wouldn’t work, it’s just a larger motor.
@RoadkillUK
this new motor controller is so nice! https://www.youtube.com/watch?v=qECEGUZE04s
everything is built in, esp chip, driver, all powered by USB-C!
it uses TMC2209 instead of TMC2208 driver.
do you think i have to modify your YML code in any way? your code is still working great for my roller shade after 1+ year so far with the TMC2208 driver.
Sorry for the late reply
I honestly don’t know, it will probably run it the same but won’t use any of the encoding … probably
