When I try to add this to my automation, I get an error. But when I test it in the template tester, I get True/False correctly. Am I doing something wrong? Thanks!
# Sun Rise and Sun Set Switch Lights
- alias: 'Turn Off Lights When Sun Rises'
platform: sun
event: sunrise
offset: '+00:00:00'
condition:
condition: template
value_template: {{ states('input_slider.cloudcover_lights') > states('sensor.yr_cloudiness') }}
- service: switch.turn_off
entity_id: switch.outside_lights_switch
2017-07-26 20:53:50 ERROR (Thread-1) [homeassistant.util.yaml] while parsing a block mapping
in â/home/homeassistant/.homeassistant/automations.yamlâ, line 8, column 5
expected , but found ââ
in â/home/homeassistant/.homeassistant/automations.yamlâ, line 9, column 33
2017-07-26 20:53:50 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: while parsing a block mapping
