Error in config, unable to trace, NEED HELP
Hi have these 4 errors popping up,
I am not an experienced dev, Just enough to help me screw up things sometimes
but I am unable to trace this
I looked through the YAML files but could not find anything related to this errors
Maybe I am looking at it wrong
Any help will be appreciated
2024-08-20 11:49:25.344 ERROR (MainThread) [homeassistant.setup] Setup failed for ‘entity’: Integration not found.
2024-08-20 11:49:25.344 ERROR (MainThread) [homeassistant.setup] Setup failed for ‘forecast_type’: Integration not found.
2024-08-20 11:49:25.345 ERROR (MainThread) [homeassistant.setup] Setup failed for ‘type’: Integration not found.
2024-08-20 11:49:25.346 ERROR (MainThread) [homeassistant.setup] Setup failed for ‘sensors’: Integration not found.
Extremely likely to be an indentation issue in one of your YAML.
I checked each YAML file with a YAML Checker, and all is fine
That it’s proper YAML doesn’t mean it’s ok HA wise :wink:
