After a recent update in core and/or core an error has come up.
The error was like Command Line YAML has moved. According to post in Github I have the Config YAML
## Cpu Core Temperature
command_line:
- sensor:
name: CPU Temperature
command: "cat /sys/class/thermal/thermal_zone0/temp"
unit_of_measurement: "°C"
value_template: '{{ value | multiply(0.001) | round(2) }}'
On Config check it fails again
Will appreciate help on this.
This is the error on config check
Invalid config for [command_line]: expected a dictionary for dictionary value @ data['command_line'][0]['sensor']. Got None
extra keys not allowed @ data['command_line'][0]['command']. Got 'cat /sys/class/thermal/thermal_zone0/temp'
extra keys not allowed @ data['command_line'][0]['name']. Got 'CPU Temperature'
extra keys not allowed @ data['command_line'][0]['unit_of_measurement']. Got '°C'
extra keys not allowed @ data['command_line'][0]['value_template']. Got '{{ value | multiply(0.001) | round(2) }}'. (See /config/configuration.yaml, line 36).
command_line:
- sensor:
Oh yes I noticed it could not figure out how to correct the error. I will put in more effort… please bear with me…
Corrected my error, thanks @nickrout !
