I am using the MQTT CLI and get this error no matter what command I use… any troubleshooting suggestions… I have the mosquito server running and the config file looks OK. Seems the connection is refused.
File “/opt/insteon-mqtt/scripts/insteon-mqtt”, line 5, in
status = insteon_mqtt.cmd_line.main()
File “/usr/lib/python3.9/site-packages/insteon_mqtt/cmd_line/main.py”, line 587, in main
return args.func(args, cfg)
File “/usr/lib/python3.9/site-packages/insteon_mqtt/cmd_line/modem.py”, line 97, in get_devices
reply = util.send(config, topic, payload, args.quiet)
File “/usr/lib/python3.9/site-packages/insteon_mqtt/cmd_line/util.py”, line 126, in send
client.connect(config[“mqtt”][“broker”], config[“mqtt”][“port”])
File “/usr/lib/python3.9/site-packages/paho/mqtt/client.py”, line 914, in connect
return self.reconnect()
File “/usr/lib/python3.9/site-packages/paho/mqtt/client.py”, line 1044, in reconnect
sock = self._create_socket_connection()
File “/usr/lib/python3.9/site-packages/paho/mqtt/client.py”, line 3685, in _create_socket_connection
return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source)
File “/usr/lib/python3.9/socket.py”, line 843, in create_connection
raise err
File “/usr/lib/python3.9/socket.py”, line 831, in create_connection
sock.connect(sa)
