current release 2025 03.3
Here is a screenshot showing the error and then an error free workaround with a good gab an proper entities
This whole error is caused by a different behaviour which should not exist.
It is caused by the position where the title is used, where this screenshot shows the usage with a proper output and a gap if the title is used there
If it his here in the “third” title line then this issue marked yellow appears again
and it is caused by the title in the 3rd line not in the 2nd.
In my opinion both should work the same cause it also does not matter in those cases where I use the first title. First and second title lines are working properly, in the 3rd things go wrong and I have no gap anymore.
It took me quite a while to figure it out with different approaches like using different cards and what not. I do not know where to post such error here for HA cause I did not find a proper section on github or I missed it
I hope someone will fix it cause it cost me 3 hours to #1 find a workaround and #2 to get it fixed and get behind the roots.
