Error in duckdns
hey i am trying to install duckdns,
and getting the following:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
# INFO: Using main config file /data/workdir/config
+ Account already registered!
[23:52:51] WARNING:
[23:52:54] INFO: Renew certificate for domains: porat.duckdns.org and aliases:
Processing porat.duckdns.org
 + Signing domains...
 + Generating private key...
 + Generating signing request...
 + Requesting new certificate order from CA...
 + Received 1 authorizations URLs from the CA
 + Handling authorization for ###.duckdns.org
 + 1 pending challenge(s)
 + Deploying challenge tokens...
ERROR: deploy_challenge hook returned with non-zero exit code
fresh install any idea why may cause this?
I have the exact same problem, it started in the last couple days. No idea why, but exactly the same.
When you say it started in the last few days, it worked before? I’m a relatively new user and wasn’t sure if I’d made an error in configuration as I’m getting this too.
Check your Key Token from DuckDNS, when copying I had grabbed a space at the start that threw this error.
fixed for me after removing and reinstalltiing
Thanks worked for me too!
Yes, the same here!
Tnx!
Same here! Thanks lol
Same here, thanks!
OMG thank you!
Yeah, that fixed all my errors I was getting in both NGINX and Duck DNS… amazing how much a little space at the front of that key can mess things up! Thanks for that tip!
Wow unbelievable i spent hours troubleshooting this shit and same exact thing when i saw what you said about the space I checked and I did the same thing haha saved the day
Same here… thank you very much :slight_smile:
Same error here, my webfilter blocked “dyndns” , made exception for duckdns en problem was solved
all this time later this post still helped me with my issue, thanks!
Sept. '24 and this is still helpful. Thanks, Nir!
Same, thanks
Jan 2025 here to certify that you are still a life saver, thanks!
I have installed Duck DNS in January, it was runnung well untill may and now I get this error message : “ERROR: deploy_challenge hook returned with non-zero exit code”
I checked the token : it seems correct. Do you have any other idea ?
Same here… running for 3 years until now
