Logger: homeassistant.backports.enum
Källa: helpers/deprecation.py:222
StrEnum was used from ebeco, this is a deprecated alias which will be removed in HA Core 2025.5. Use enum.StrEnum instead, please report it to the author of the ‘ebeco’ custom integration.
2025-01-21 11:43:52.275 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration ebeco which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-21 11:47:14.541 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ebeco which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-21 11:47:21.952 WARNING (ImportExecutor_0) [homeassistant.backports.enum] StrEnum was used from ebeco, this is a deprecated alias which will be removed in HA Core 2025.5. Use enum.StrEnum instead, please report it to the author of the ‘ebeco’ custom integration
KeyError: <custom_components.ebeco.config_flow.EbecoFlowHandler object at 0x7f6d448c27b0>
KeyError: <custom_components.ebeco.config_flow.EbecoFlowHandler object at 0x7f6d44943610>
2025-01-21 12:21:43.451 WARNING (SyncWorker_5) [homeassistant.loader] We found a custom integration ebeco which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-01-21 12:22:22.227 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ebeco which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
