maurizio53
(Maurizio Fabiani)
March 28, 2018, 4:21pm
1
What does it means this error:
“Updating device list from nmap_tracker took longer than the scheduled scan interval 0:00:30”
About nmap track i have this in config file:
- platform: nmap_tracker
hosts:
- 192.168.1.0/24
scan_options: " --privileged -sP "
interval_seconds: 30
home_interval: 10
exclude:
- 192.168.1.1
- 192.168.1.2
- 192.168.1.3
- 192.168.1.4
- 192.168.1.5
- 192.168.1.7
- 192.168.1.8
- 192.168.1.9
- 192.168.1.10
- 192.168.1.11
- 192.168.1.13
- 192.168.1.14
- 192.168.1.15
- 192.168.1.16
- 192.168.1.17
- 192.168.1.19
- 192.168.1.20
- 192.168.1.21
- 192.168.1.22
- 192.168.1.23
- 192.168.1.24
- 192.168.1.29
new_device_defaults:
track_new_devices: no
hide_if_away: True
And how to get rid of this?
silvrr
March 28, 2018, 4:37pm
2
May be due to you scanning ~225 IPs every 30 seconds.
Try listing the hosts you want to scan or otherwise decrease the total number of scans being performed.
You can list ranges or just cite the specific IPs you want scanned.
maurizio53
(Maurizio Fabiani)
March 28, 2018, 6:18pm
3
Can you give me an example of what you are advicing me?
silvrr
March 28, 2018, 6:25pm
4
My DHCP server only hands out IPs in the range of 51-60 and my statically assigned IPs are below 40 currently. Therefore I use the following setup.
https://github.com/SilvrrGIT/HomeAssistant/blob/master/device_tracker.yaml#L25
Your current setup says scan the hosts in 192.168.1.0/24 which is 192.168.1.1-192.168.1.254, thats 253 hosts to scan, your exclude removes 20-25 of those but there is still a large number to scan.
hosts:
- 192.168.1.6
- 192.168.1.12
- 192.168.1.18
- 192.168.1.25-29
The above would scan your currently scanned hosts below the .30 IP range. If you know you will have hosts above the .30 IP range you can add a range to catch those. 192.168.1.30-50 for example. Even with this last range added you would be scanning 28 IPs instead of in the 200 range.
maurizio53
(Maurizio Fabiani)
March 28, 2018, 6:30pm
5
Ok thanks… i want to scan only 2 IP (my phone and my wife phone) and want to exclude all those i put in the exclude list… can you give me the right config for my purpose? I am just beginning to use HASS…
silvrr
March 28, 2018, 6:43pm
6
OK, you are scanning way to much if you only want to track two phones.
Only tell it to scan the IP of your phones then. If they don’t have a static IP assigned in your router it is a good idea to do so.
hosts:
- 192.168.1.##
- 192.168.1.##
That will only scan two IP addresses. Finish off the 192.168.1.## with the appropriate IP address of the two phones.
maurizio53
(Maurizio Fabiani)
March 28, 2018, 6:48pm
7
Ok i did it and i already have static IP assigned to them… and what about the exclude list?
silvrr
March 28, 2018, 6:59pm
8
Not required. You are only telling it to scan those two IPs, no other IPs will be scanned.
maurizio53
(Maurizio Fabiani)
March 28, 2018, 7:02pm
9
So what’s the meaning of the exclude option? I followed the instructions on home assistant page
silvrr
March 28, 2018, 7:15pm
10
Just as you were using it above.
If you tell nmap to scan a whole subnet (192.168.1.0/24 for example) It will scan 192.168.1.1 - 192.168.1.254.
You can then tell it to exclude certain IPs from that range so they are not scanned.
If you only tell nmap to scan two IPs, the exclude option is not used.
silvrr
March 28, 2018, 8:45pm
11
After all that, did the error in the log go away?
Donovan
(Donovan)
November 26, 2018, 12:06pm
13
Simple truck to prevent the spam is to divide the nmap
I split it in most changed device (dhcp 192.168.22.0-50 and some crap 200-255) every 1 minute
second one 51-199 every 10 min
No more spam!!
device_tracker:
hosts:
- 192.168.22.0-50
- 192.168.22.200-255
home_interval: 1
hosts:
- 192.168.22.51-199
home_interval: 10
