I realised I’ve got this error:
2019-06-18 08:12:30 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform legacy
File "/usr/local/lib/python3.7/site-packages/bluetooth/bluez.py", line 31, in discover_devices
lookup_class=lookup_class, device_id=device_id)
_bluetooth.error: (110, 'Operation timed out')
File "/usr/src/homeassistant/homeassistant/components/device_tracker/setup.py", line 76, in async_setup_legacy
tracker.see, discovery_info)
File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 82, in setup_scanner
for dev in discover_devices():
File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 57, in discover_devices
lookup_class=False, device_id=device_id)
File "/usr/local/lib/python3.7/site-packages/bluetooth/bluez.py", line 34, in discover_devices
raise BluetoothError ("error communicating with local "
bluetooth.btcommon.BluetoothError: error communicating with local bluetooth adapter
Could you help me understanding what is wrong?
Thank You
Regards
