Error in isy994 component after upgrade to 5.0.10
Hey all,
I updated the ISY994 to 5.0.10, and HA functionality seemed to work just fine. However, after restarting HA later on, I now get the following error:
2017-05-11 16:48:27 ERROR (MainThread) [homeassistant.setup] Error during setup of component isy994
  File "/usr/src/app/homeassistant/setup.py", line 188, in _async_setup_component
    None, component.setup, hass, processed_config)
  File "uvloop/future.pyx", line 230, in __iter__ (uvloop/loop.c:110600)
  File "uvloop/future.pyx", line 432, in uvloop.loop.BaseTask._fast_wakeup (uvloop/loop.c:113980)
  File "uvloop/future.pyx", line 101, in uvloop.loop.BaseFuture._result_impl (uvloop/loop.c:108900)
  File "/usr/local/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/usr/src/app/homeassistant/components/isy994.py", line 192, in setup
    use_https=https, tls_ver=tls_version, log=_LOGGER)
  File "/usr/local/lib/python3.5/site-packages/PyISY/ISY.py", line 84, in __init__
    self.nodes = Nodes(self, xml=self.conn.getNodes())
  File "/usr/local/lib/python3.5/site-packages/PyISY/Nodes/__init__.py", line 73, in __init__
    self.parse(xml)
  File "/usr/local/lib/python3.5/site-packages/PyISY/Nodes/__init__.py", line 220, in parse
    nval = int(nval.replace(' ', '0'))
ValueError: invalid literal for int() with base 10: ''
This is with 0.44.2 btw.
Thoughts?
