Error in loading Home Assistant
Hi.
I updated HA from version 0.92 to version 0.97 and python at version 3.7.x. But I read the register. I found some mistakes that weren’t there before. Why?
this is a log
2019-08-22 18:08:14 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /home/homeassistant/.homeassistant/configuration.yaml contains duplicate key "service_name". Check lines 52 and 57.
2019-08-22 18:08:14 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /home/homeassistant/.homeassistant/configuration.yaml contains duplicate key "chat_id". Check lines 299 and 300.
2019-08-22 18:08:14 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /home/homeassistant/.homeassistant/configuration.yaml contains duplicate key "chat_id". Check lines 300 and 301.
2019-08-22 18:08:15 WARNING (MainThread) [homeassistant.components.http] Configuring api_password via the http integration has been deprecated. Use the legacy api password auth provider instead. For instructions, see https://www.home-assistant.io/docs/authentication/providers/#legacy-api-password
2019-08-22 18:08:15 WARNING (MainThread) [homeassistant.components.http.auth] legacy_api_password support has been enabled.
2019-08-22 18:08:22 ERROR (MainThread) [homeassistant.setup] Error during setup of component cloud
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/setup.py", line 168, in _async_setup_component
    hass, processed_config
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/cloud/__init__.py", line 167, in async_setup
    from hass_nabucasa import Cloud
  File "/srv/homeassistant/lib/python3.7/site-packages/hass_nabucasa/__init__.py", line 16, in <module>
    from .remote import RemoteUI
  File "/srv/homeassistant/lib/python3.7/site-packages/hass_nabucasa/remote.py", line 16, in <module>
    from .acme import AcmeClientError, AcmeHandler
  File "/srv/homeassistant/lib/python3.7/site-packages/hass_nabucasa/acme.py", line 9, in <module>
    import OpenSSL
  File "/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/__init__.py", line 8, in <module>
    from OpenSSL import crypto, SSL
  File "/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/crypto.py", line 16, in <module>
    from OpenSSL._util import (
  File "/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/_util.py", line 6, in <module>
    from cryptography.hazmat.bindings.openssl.binding import Binding
  File "/srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/bindings/openssl/binding.py", line 15, in <module>
    from cryptography.hazmat.bindings._openssl import ffi, lib
ImportError: /usr/lib/arm-linux-gnueabihf/libssl.so.1.1: version `OPENSSL_1_1_1' not found (required by /srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/bindings/_openssl.abi3.so)
2019-08-22 18:08:23 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: cloud
2019-08-22 18:08:23 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2019-08-22 21:57:38 WARNING (Thread-4) [pychromecast.socket_client] [Soggiorno:8009] Heartbeat timeout, resetting connection
2019-08-22 21:57:39 WARNING (Thread-3) [pychromecast.socket_client] [Camera dei genitori:8009] Heartbeat timeout, resetting connection
2019-08-22 21:57:43 WARNING (Thread-2) [pychromecast.socket_client] [Camera di Andrea:8009] Heartbeat timeout, resetting connection
2019-08-22 21:57:59 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 21:58:25 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 21:58:51 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 21:59:17 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 21:59:43 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:00:09 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:00:35 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:01:01 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:01:27 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:01:53 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:02:19 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:02:45 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:03:11 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:03:37 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:04:03 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:04:29 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:04:55 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:05:21 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:05:47 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:06:13 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:06:39 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:07:05 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:07:31 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:07:57 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:08:23 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:08:49 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:09:15 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:09:41 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:10:07 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-22 22:10:33 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
to the why
short google search:
Thanks. It’s work!
