Logger: charset_normalizer
Source: /home/homeassistant/.pyenv/versions/3.9.9/lib/python3.9/site-packages/charset_normalizer/api.py:78
First occurred: 21 december 2021 06:52:22 (330 occurrences)
Last logged: 08:00:59
Encoding detection on empty bytes, assuming utf_8 intention.
I have the same output. I believe the charset_normalizer lib is deeply rooted in HA used to detect charset encoding. So probably used by device auto discovery, parsing XML, etc. I will try to enable debug logging for this lib, it is getting a bit annoying.
I am running home-assistant core in a virtual environment and I get the same error. I have 56 repeats within a 14 hour period. The errors started after I upgraded from Python 3.8.5 to 3.9.7. in the virtual environment.
Source: /usr/local/lib/python3.9/site-packages/charset_normalizer/api.py:121
First occurred: 5:16:40 PM (1 occurrences)
Last logged: 5:16:40 PM
Trying to detect encoding from a tiny portion of (9) byte(s).
Mine occurs during the bootup. Has anyone tried raising an issue on GitHub?
