Hello…
I’m fighting with an error but can’t get to understand why it’s here… Here’s my automation script
alias: Thermostat - Fan Only
description: ''
- platform: mqtt
topic: Tasmota_HVAC/HASS/Mode
condition: []
- service_template: >
{% if is_state('climate.study_mqtt', 'fan_only') and
is_state('switch.hvac_fan','off') %}
switch.turn_on
{% elif not is_state('climate.study_mqtt', 'fan_only') and
is_state('switch.hvac_fan','on') %}
switch.turn_off
{% endif %}
entity_id: switch.hvac_fan
mode: single
And I get this error in the log: Error executing script. Unexpected error for call_service at pos 1: Template rendered invalid service
Interestingly, the automation works with no problem…
Here is the detailed log:
Logger: homeassistant.components.automation.thermostat_fan_only
Source: helpers/service.py:172
Integration: Automation (documentation, issues)
First occurred: January 2, 2021, 10:38:29 AM (32 occurrences)
Last logged: 1:04:15 PM
Thermostat - Fan Only: Error executing script. Unexpected error for call_service at pos 1: Template rendered invalid service:
While executing automation automation.thermostat_fan_only
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 166, in async_prepare_call_from_config
domain_service = cv.service(domain_service)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 463, in service
raise vol.Invalid(f"Service {value} does not match format <domain>.<name>")
voluptuous.error.Invalid: Service does not match format <domain>.<name>
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 250, in _async_step
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 429, in _async_call_service_step
domain, service_name, service_data = service.async_prepare_call_from_config(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 172, in async_prepare_call_from_config
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Template rendered invalid service:
Any idea of what’s wrong here?
Thanks!
