I have this error in the log apparently related to the Node-RED addon.
I have just run a load of updates (inc OS and Core) and I don’t think this was there before.
Can anyone tell me if this is an error in the addon or the Flows themselves (nothing in NR log).
2023-11-28 21:33:12.663 ERROR (MainThread) [homeassistant.util.logging] Exception in async_discover when dispatching 'nodered_discovery_new_time': ({'state': 1699011877838, 'attributes': {}, 'type': 'nodered/discovery', 'server_id': 'a8c279c8.be8be8', 'node_id': '47cacacf970a4013', 'config': {'name': 'Node-RED status time'}, 'component': 'time', 'device_info': {'id': 'cbee261aebc1a534', 'hw_version': '', 'name': 'NR Status', 'manufacturer': 'Node-RED', 'model': '', 'sw_version': ''}, 'id': 19}, <ActiveConnection Supervisor>)
File "/config/custom_components/nodered/time.py", line 30, in async_discover
await _async_setup_entity(hass, config, async_add_entities, connection)
File "/config/custom_components/nodered/time.py", line 42, in _async_setup_entity
async_add_entities([NodeRedNumber(hass, config, connection)])
File "/config/custom_components/nodered/time.py", line 61, in __init__
super().__init__(hass, config)
File "/config/custom_components/nodered/__init__.py", line 116, in __init__
self.update_entity_state_attributes(config)
File "/config/custom_components/nodered/time.py", line 76, in update_entity_state_attributes
self._attr_native_value = _convert_string_to_time(msg.get(CONF_STATE))
File "/config/custom_components/nodered/time.py", line 49, in _convert_string_to_time
return parser.parse(value).time()
File "/usr/local/lib/python3.11/site-packages/dateutil/parser/_parser.py", line 1368, in parse
return DEFAULTPARSER.parse(timestr, **kwargs)
File "/usr/local/lib/python3.11/site-packages/dateutil/parser/_parser.py", line 640, in parse
res, skipped_tokens = self._parse(timestr, **kwargs)
File "/usr/local/lib/python3.11/site-packages/dateutil/parser/_parser.py", line 719, in _parse
l = _timelex.split(timestr) # Splits the timestr into tokens
File "/usr/local/lib/python3.11/site-packages/dateutil/parser/_parser.py", line 201, in split
return list(cls(s))
File "/usr/local/lib/python3.11/site-packages/dateutil/parser/_parser.py", line 69, in __init__
raise TypeError('Parser must be a string or character stream, not '
TypeError: Parser must be a string or character stream, not int
