Error in log - two port references in the Influx path
In the log I see the port no is given 2 times in the url, and I cannot find the cause for this! Anything anyone have seen before?
2022-09-07 09:40:57.664 ERROR (SyncWorker_7) [homeassistant.components.influxdb.sensor] Cannot connect to InfluxDB due to 'Failed to parse: http://192.168.77.45:8086:8086/query'. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible.
Well, what’s you config?
Here is mine
influxdb:
  host: influxdb.lan
  port: 8086
It like this:
influxdb:
  host: a0d7b954-influxdb
  port: 8086
  database: !secret influx_database
  username: !secret influx_username
  password: !secret influx_password
  max_retries: 9
  default_measurement: state
Answer to myself…
I have a sensor defined, containing the current size of the Influx database. In the definition for this sensor I had put the ip-address with the port no. and also defined the port itself. Hence two port no’s inte the query…
Shame face, but glad to have found the problem!
