Error in log: unit of sensor cannot be converted to the unit of previously compiled statistics
Hi, I’m having this warning in the log that I can’t resolve.
2026-10-09 16:15:10.372 WARNING (Recorder) [homeassistant.components.sensor.recorder] The unit of sensor.hansabakken_kwh_h (kWh/h) cannot be converted to the unit of previously compiled statistics (kW). Generation of long term statistics will be suppressed unless the unit changes back to kW or a compatible unit. Go to https://my.home-assistant.io/redirect/developer_statistics to fix this
sensor.hansabakken_kwh_h is a derivate helper derivating a kwh sensor.
I’ve tried going to the tools → statistics deleting the statistics for the entity, hoping it would start over with the correct unit, but apparently not.
This is a warning that didn’t come straigt away, but has been for a while.
Does anyone know what I can do to resolve this warning?
