I’ve got a Heatpump I manage with Modbus.
Since the beginning I received this Errormessages:
Modbus modbus_WP-Pool/sensor.IXCR66_Water_inlet_temp address modbus_WP-Pool3_input_1 is duplicate, second entry not loaded!
I can’t find the mistake I’ve made.
My config:
- name: modbus_WP-Pool
type: tcp
host: IP
port: 8899
sensors:
################ WP Zähler SDM120m ################
- name: "WP-Pool_W"
unit_of_measurement: W
slave: 2
address: 12
input_type: input
#precision: 3
scan_interval: 10
device_class: Power
state_class: measurement
data_type: float32
- name: "WP-Pool_kWh"
unit_of_measurement: kWh
slave: 2
address: 72
input_type: input
#precision: 4
scan_interval: 10
device_class: energy
state_class: total_increasing
data_type: float32
################ WP IXCR66 ################
- name: IXCR66_Mode
unique_id: IXCR66_HR_0
slave: 1
address: 0
input_type: holding
data_type: int16
- name: IXCR66_Silence
unique_id: IXCR66_HR_1
slave: 1
address: 1
input_type: input
data_type: int16
- name: IXCR66_Set_temp
unique_id: IXCR66_HR_3
slave: 1
address: 3
input_type: holding
data_type: int16
offset: -30
scale: 0.5
device_class: temperature
unit_of_measurement: °C
- name: IXCR66_Speed
unique_id: IXCR66_IR_0
slave: 1
address: 0
input_type: input
data_type: int16
- name: IXCR66_Water_inlet_temp
unique_id: IXCR66_IR_3
slave: 1
address: 3
input_type: input
data_type: int16
precision: 1
offset: -30
scale: 0.5
- name: IXCR66_Water_outlet_temp
unique_id: IXCR66_IR_4
slave: 1
address: 4
input_type: input
data_type: int16
precision: 1
offset: -30
scale: 0.5
- name: IXCR66_Outside_temp
unique_id: IXCR66_IR_5
slave: 1
address: 5
input_type: input
data_type: int16
precision: 1
offset: -30
scale: 0.5
- name: IXCR66_min_Set_temp
unique_id: IXCR66_IR_17
slave: 1
address: 17
input_type: input
data_type: int16
precision: 0
offset: -30
scale: 0.5
- name: IXCR66_max_Set_temp
unique_id: IXCR66_IR_18
slave: 1
address: 18
input_type: input
data_type: int16
precision: 0
offset: -30
scale: 0.5
climates:
- name: "IXCR66"
slave: 1
address: 3
input_type: input
data_type: int16
max_temp: 40
min_temp: 18
offset: -30
precision: 1
scale: 0.5
target_temp_register: 3
temp_step: 1
temperature_unit: C
hvac_mode_register:
address: 1
write_registers: false
values:
state_auto: 1
state_heat: 0
hvac_onoff_register: 0
switches:
- name: IXCR66_Power
unique_id: IXCR66_Power
slave: 1
address: 0
command_on: 1
command_off: 0
write_type: coil
verify:
input_type: coil
address: 0
delay: 1
state_on: 1
state_off: 0
binary_sensors:
- name: IXCR66_On_Off
unique_id: IXCR66_DI_0
slave: 1
address: 0
input_type: discrete_input
- name: IXCR66_Defrosting
unique_id: IXCR66_DI_1
slave: 1
address: 1
- name: IXCR66_Error_E0
unique_id: IXCR66_DI_48
slave: 1
address: 48
device_class: problem
- name: IXCR66_Error_E1
unique_id: IXCR66_DI_49
slave: 1
address: 49
- name: IXCR66_Error_E2
unique_id: IXCR66_DI_50
slave: 1
address: 50
- name: IXCR66_Error_E3
unique_id: IXCR66_DI_51
slave: 1
address: 51
- name: IXCR66_Error_E4
unique_id: IXCR66_DI_52
slave: 1
address: 52
- name: IXCR66_Error_E5
unique_id: IXCR66_DI_53
slave: 1
address: 53
- name: IXCR66_Error_E6
unique_id: IXCR66_DI_54
slave: 1
address: 54
- name: IXCR66_Error_E7
unique_id: IXCR66_DI_55
slave: 1
address: 55
- name: IXCR66_Error_E8
unique_id: IXCR66_DI_56
slave: 1
address: 56
- name: IXCR66_Error_E9
unique_id: IXCR66_DI_57
slave: 1
address: 57
- name: IXCR66_Error_EA
unique_id: IXCR66_DI_58
slave: 1
address: 58
- name: IXCR66_Error_EB
unique_id: IXCR66_DI_59
slave: 1
address: 59
- name: IXCR66_Error_ED
unique_id: IXCR66_DI_61
slave: 1
address: 61
- name: IXCR66_Error_P0
unique_id: IXCR66_DI_64
slave: 1
address: 64
- name: IXCR66_Error_P1
unique_id: IXCR66_DI_65
slave: 1
address: 65
- name: IXCR66_Error_P2
unique_id: IXCR66_DI_66
slave: 1
address: 66
- name: IXCR66_Error_P3
unique_id: IXCR66_DI_67
slave: 1
address: 67
- name: IXCR66_Error_P4
unique_id: IXCR66_DI_68
slave: 1
address: 68
- name: IXCR66_Error_P5
unique_id: IXCR66_DI_69
slave: 1
address: 69
- name: IXCR66_Error_P6
unique_id: IXCR66_DI_70
slave: 1
address: 70
- name: IXCR66_Error_P7
unique_id: IXCR66_DI_71
slave: 1
address: 71
- name: IXCR66_Error_P8
unique_id: IXCR66_DI_72
slave: 1
address: 72
- name: IXCR66_Error_P9
unique_id: IXCR66_DI_73
slave: 1
address: 73
- name: IXCR66_Error_PA
unique_id: IXCR66_DI_74
slave: 1
address: 74
- name: IXCR66_Error_F0
unique_id: IXCR66_DI_80
slave: 1
address: 80
- name: IXCR66_Error_F1
unique_id: IXCR66_DI_81
slave: 1
address: 81
- name: IXCR66_Error_F2
unique_id: IXCR66_DI_82
slave: 1
address: 82
- name: IXCR66_Error_F3
unique_id: IXCR66_DI_83
slave: 1
address: 83
- name: IXCR66_Error_F4
unique_id: IXCR66_DI_84
slave: 1
address: 84
- name: IXCR66_Error_F5
unique_id: IXCR66_DI_85
slave: 1
address: 85
- name: IXCR66_Error_F6
unique_id: IXCR66_DI_86
slave: 1
address: 86
- name: IXCR66_Error_F7
unique_id: IXCR66_DI_87
slave: 1
address: 87
- name: IXCR66_Error_F8
unique_id: IXCR66_DI_88
slave: 1
address: 88
- name: IXCR66_Error_F9
unique_id: IXCR66_DI_89
slave: 1
address: 89
- name: IXCR66_Error_FB
unique_id: IXCR66_DI_91
slave: 1
address: 91
Btw. everything is working.
Have anybody a solution or me?
