Getting error in mqtt sensor entity code from documentation.
Link to documentation: MQTT Sensor - Home Assistant
mqtt:
- sensor:
state_topic: "home/bedroom/temperature"
Error: Incorrect type : Expected “Object”
mqtt:
- sensor:
That’s a problem with the VSCode home assistant helper extension schema, not the documentation.
You can report it as a new issue here (if it has not already been reported):
Or submit a fix yourself:
