A bunch of error i haven’t had time to deal with, but nothing regarding the automation section.
16-12-30 17:30:02 homeassistant.components.media_player: Error while setting up platform squeezebox
File "/home/michel/.local/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py", line 150, in _async_setup_platform
entity_platform.add_entities, discovery_info
File "/usr/lib/python3.5/asyncio/futures.py", line 361, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 296, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 274, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/home/michel/.local/lib/python3.5/site-packages/homeassistant/components/media_player/squeezebox.py", line 77, in setup_platform
add_devices(lms.create_players())
File "/home/michel/.local/lib/python3.5/site-packages/homeassistant/components/media_player/squeezebox.py", line 106, in create_players
for index in range(0, int(count)):
ValueError: invalid literal for int() with base 10: 'Allowed</TITLE></HEAD>'
16-12-30 17:30:08 homeassistant.components.http: Failed to create HTTP server at port 8123: [Errno 98] error while attempting to bind on address ('0.0.0.0', 8123): address already in use
16-12-30 17:30:08 homeassistant.components.recorder: Ended unfinished session (id=56 from 2016-12-30 16:26:58.546655)
16-12-30 17:30:08 homeassistant.components.recorder: Found unfinished sessions
16-12-30 17:30:16 plexapi: http://10.0.0.10:32400: (401) unauthorized
I pressed dismiss on the error-message, and it disapperad. Could it be an old message, and now with i working conf-file i stuck around until i dismissed it?
I think I read somewhere that special characters can cause a problem in the titles. That was probably an older release and it may have been fixed, it may not have.
