I am not able to use recorder with MySQL. Despite successful installation of MySQL server, client, elements of HASS for connection with MySQL, passwords, connection from localhost and not only, etc…
I’m getting the following in the syslog:
Dec 14 22:58:06 raspberrypi hass[17359]: File "/home/hass/.homeassistant/deps/sqlalchemy/dialects/mysql/mysqldb.py", line 110, in dbapi
Line 110 in this file refers to:
return __import__('MySQLdb')
I’m guessing Python doesn’t have this package?
Any ideas will be appreciated.
Same here. Following the documentation but it did not help.
Jan 18 18:44:30 homeassistant hass[31560]: Exception in thread Thread-9:
Jan 18 18:44:30 homeassistant hass[31560]: Traceback (most recent call last):
Jan 18 18:44:30 homeassistant hass[31560]: File "/usr/lib/python3.4/threading.py", line 920, in _bootstrap_inner
Jan 18 18:44:30 homeassistant hass[31560]: self.run()
Jan 18 18:44:30 homeassistant hass[31560]: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/recorder/__init__.py", line 204, in run
Jan 18 18:44:30 homeassistant hass[31560]: self._setup_connection()
Jan 18 18:44:30 homeassistant hass[31560]: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/recorder/__init__.py", line 303, in _setup_connection
Jan 18 18:44:30 homeassistant hass[31560]: self.engine = create_engine(self.db_url, echo=False)
Jan 18 18:44:30 homeassistant hass[31560]: File "/home/homeassistant/.homeassistant/deps/sqlalchemy/engine/__init__.py", line 387, in create_engine
Jan 18 18:44:30 homeassistant hass[31560]: return strategy.create(*args, **kwargs)
Jan 18 18:44:30 homeassistant hass[31560]: File "/home/homeassistant/.homeassistant/deps/sqlalchemy/engine/strategies.py", line 80, in create
Jan 18 18:44:30 homeassistant hass[31560]: dbapi = dialect_cls.dbapi(**dbapi_args)
Jan 18 18:44:30 homeassistant hass[31560]: File "/home/homeassistant/.homeassistant/deps/sqlalchemy/dialects/mysql/mysqldb.py", line 110, in dbapi
Jan 18 18:44:30 homeassistant hass[31560]: return __import__('MySQLdb')
Jan 18 18:44:30 homeassistant hass[31560]: ImportError: No module named 'MySQLdb'
Jan 18 1
While this is working a maybe better approach is to just install mysqlclient, a Python 3 compatible mysql-python fork. Because (as I understand) this package uses c-extensions and is thus theoretically faster then the pure python pymsql package.
Nevermind, found it: sudo apt-get install libmysqlclient-dev
In the virtual environment: pip3 install mysqlclient
Trying to use mysql on my NAS.
HASS errors out with:
Feb 15 22:46:06 Condor1 hass[4805]: Exception in thread Thread-9:
Feb 15 22:46:06 Condor1 hass[4805]: Traceback (most recent call last):
Feb 15 22:46:06 Condor1 hass[4805]: File "/usr/lib/python3.4/threading.py", line 920, in _bootstrap_inner
Feb 15 22:46:06 Condor1 hass[4805]: self.run()
Feb 15 22:46:06 Condor1 hass[4805]: File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/recorder/__init__.py", line 211, in run
Feb 15 22:46:06 Condor1 hass[4805]: self._setup_connection()
Feb 15 22:46:06 Condor1 hass[4805]: File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/recorder/__init__.py", line 311, in _setup_connection
Feb 15 22:46:06 Condor1 hass[4805]: self.engine = create_engine(self.db_url, echo=False)
Feb 15 22:46:06 Condor1 hass[4805]: File "/home/hass/.homeassistant/deps/sqlalchemy/engine/__init__.py", line 387, in create_engine
Feb 15 22:46:06 Condor1 hass[4805]: return strategy.create(*args, **kwargs)
Feb 15 22:46:06 Condor1 hass[4805]: File "/home/hass/.homeassistant/deps/sqlalchemy/engine/strategies.py", line 80, in create
Feb 15 22:46:06 Condor1 hass[4805]: dbapi = dialect_cls.dbapi(**dbapi_args)
Feb 15 22:46:06 Condor1 hass[4805]: File "/home/hass/.homeassistant/deps/sqlalchemy/dialects/mysql/mysqldb.py", line 110, in dbapi
Feb 15 22:46:06 Condor1 hass[4805]: return __import__('MySQLdb')
Feb 15 22:46:06 Condor1 hass[4805]: ImportError: No module named 'MySQLdb'
Tried to install the mysqlclient in my virtuall environment:
This errors out with:
hass@Condor1:/home/pi$ source /srv/hass/hass_venv/bin/activate
(hass_venv) hass@Condor1:/home/pi$ pip install mysqlclient
Collecting mysqlclient
Downloading mysqlclient-1.3.9.tar.gz (81kB)
100% |████████████████████████████████| 81kB 1.2MB/s
Complete output from command python setup.py egg_info:
/bin/sh: 1: mysql_config: not found
File "<string>", line 1, in <module>
File "/tmp/pip-build-4_26ji9c/mysqlclient/setup.py", line 17, in <module>
metadata, options = get_config()
File "/tmp/pip-build-4_26ji9c/mysqlclient/setup_posix.py", line 44, in get_config
libs = mysql_config("libs_r")
File "/tmp/pip-build-4_26ji9c/mysqlclient/setup_posix.py", line 26, in mysql_config
raise EnvironmentError("%s not found" % (mysql_config.path,))
OSError: mysql_config not found
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-4_26ji9c/mysqlclient/
Downloading https://files.pythonhosted.org/packages/ec/fd/83329b9d3e14f7344d1cb31f128e6dbba70c5975c9e57896815dbb1988ad/mysqlclient-1.3.13.tar.gz (90kB)
100% |████████████████████████████████| 92kB 1.1MB/s
File “”, line 1, in
File “/tmp/pip-install-sy8hhwth/mysqlclient/setup.py”, line 18, in
File “/tmp/pip-install-sy8hhwth/mysqlclient/setup_posix.py”, line 53, in get_config
libs = mysql_config(“libs_r”)
File “/tmp/pip-install-sy8hhwth/mysqlclient/setup_posix.py”, line 28, in mysql_config
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-install-sy8hhwth/mysqlclient/
Solved: just do sudo apt install libmysqlclient-dev
then go back into the venv and pip3 install -u mysqlclient
