I am accessing an external MariaDB instance to get and display some data from my home heating system. This went fine for the last years. Since the latest update of Home Assistent, I am getting “not available” in th UI for these values after a fresh start of home assistant OS.
When checking the SQL Intergration, I can see “configuration errors” for these values. After clicking on the three dots and “re-load”, the errors vanish and the values are displayed correctly in the GUI.
When checking the log I can see
Logger: homeassistant.config_entries
Quelle: config_entries.py:637
Erstmals aufgetreten: 00:12:09 (6 Vorkommnisse)
Zuletzt protokolliert: 00:12:09Error setting up entry PumpenschachtVolumen for sql
Error setting up entry TemperaturAußen for sql
Error setting up entry TemperaturVorlauf for sql
Error setting up entry TemperaturKessel for sql
Error setting up entry TemperaturSolar for sql
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 637, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/sql/init.py”, line 110, in async_setup_entry
redact_credentials(get_instance(hass).db_url),
File “/usr/src/homeassistant/homeassistant/helpers/recorder.py”, line 76, in get_instance
return hass.data[DATA_INSTANCE]
KeyError: ‘recorder_instance’
I am using the Home Assistant recorder with a seperate MariaDB instance.
Can anybody help? Always reloading the entities after every restart is not funny…
Cheers,
Stefan
