Hi together,
can somebody help me with the following error massage - i have no idea to fix it.
2024-01-08 18:04:17.554 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=({{ as_timedelta((value | float(0) * 60) | string) }}) renders=2>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 567, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2305, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.11/site-packages/jinja2/environment.py", line 1301, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.11/site-packages/jinja2/environment.py", line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1984, in forgiving_float_filter
return float(value)
jinja2.exceptions.UndefinedError: 'value' is undefined
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 693, in async_render_to_info
render_info._result = self.async_render(
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 569, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: UndefinedError: 'value' is undefined
2024-01-08 18:04:17.559 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=({{ as_timedelta((value | float(0) * 60) | string) }}) renders=6>
return float(value)
