In the log it gives me the following error code, at first I see that the error is in the name of the list “compras” not “comprasa” but I check all the cards and codes and it is correctly placed
Registrador: homeassistant.helpers.event
Fuente: helpers/template.py:587
Ocurrió por primera vez: 17:49:56 (27 ocurrencias)
Último inicio de sesión: 20:27:24
Error while processing template: Template<template=({% if states('todo.google_keep_lista_de_comprasa') | int >= 15 %} ha-state-icon { animation: beat 2s ease-out infinite both; transform-origin: 50% 50%; } @keyframes beat { 0% { transform: scale(1); } 10% { transform: scale(1.2); } 17% { transform: scale(1.05); } 33% { transform: scale(1.30); } 60% { transform: scale(1); } } ha-card { --primary-text-color: #ffffff; --secondary-text-color: #ffff00; background: linear-gradient( rgba(238, 82, 79, 1), rgba(181, 42, 39, 1) ) }}'); } {% endif %}) renders=70>
Error while processing template: Template<template=({% if states('todo.google_keep_lista_de_comprasa') | int >= 15 %} ha-state-icon { animation: beat 2s ease-out infinite both; transform-origin: 50% 50%; } @keyframes beat { 0% { transform: scale(1); } 10% { transform: scale(1.2); } 17% { transform: scale(1.05); } 33% { transform: scale(1.30); } 60% { transform: scale(1); } } ha-card { --primary-text-color: #ffffff; --secondary-text-color: #ffff00; background: linear-gradient( rgba(238, 82, 79, 1), rgba(181, 42, 39, 1) ) }}'); } {% endif %}) renders=74>
Error while processing template: Template<template=({% if states('todo.google_keep_lista_de_comprasa') | int >= 15 %} ha-state-icon { animation: beat 2s ease-out infinite both; transform-origin: 50% 50%; } @keyframes beat { 0% { transform: scale(1); } 10% { transform: scale(1.2); } 17% { transform: scale(1.05); } 33% { transform: scale(1.30); } 60% { transform: scale(1); } } ha-card { --primary-text-color: #ffffff; --secondary-text-color: #ffff00; background: linear-gradient( rgba(238, 82, 79, 1), rgba(181, 42, 39, 1) ) }}'); } {% endif %}) renders=78>
Error while processing template: Template<template=({% if states('todo.google_keep_lista_de_comprasa') | int >= 15 %} ha-state-icon { animation: beat 2s ease-out infinite both; transform-origin: 50% 50%; } @keyframes beat { 0% { transform: scale(1); } 10% { transform: scale(1.2); } 17% { transform: scale(1.05); } 33% { transform: scale(1.30); } 60% { transform: scale(1); } } ha-card { --primary-text-color: #ffffff; --secondary-text-color: #ffff00; background: linear-gradient( rgba(238, 82, 79, 1), rgba(181, 42, 39, 1) ) }}'); } {% endif %}) renders=82>
Error while processing template: Template<template=({% if states('todo.google_keep_lista_de_comprasa') | int >= 15 %} ha-state-icon { animation: beat 2s ease-out infinite both; transform-origin: 50% 50%; } @keyframes beat { 0% { transform: scale(1); } 10% { transform: scale(1.2); } 17% { transform: scale(1.05); } 33% { transform: scale(1.30); } 60% { transform: scale(1); } } ha-card { --primary-text-color: #ffffff; --secondary-text-color: #ffff00; background: linear-gradient( rgba(238, 82, 79, 1), rgba(181, 42, 39, 1) ) }}'); } {% endif %}) renders=86>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 585, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2600, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 1304, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 939, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2243, in forgiving_int_filter
raise_no_default("int", value)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1849, in raise_no_default
raise ValueError(
ValueError: Template error: int got invalid input 'unknown' when rendering template '{% if states('todo.google_keep_lista_de_comprasa') | int >= 15 %}
ha-state-icon {
@keyframes beat {
ha-card {
{% endif %}' but no default was specified
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 713, in async_render_to_info
render_info._result = self.async_render(
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 587, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: ValueError: Template error: int got invalid input 'unknown' when rendering template '{% if states('todo.google_keep_lista_de_comprasa') | int >= 15 %}
ha-state-icon {
@keyframes beat {
ha-card {
Thanks in advance
