I’m trying to create a sensor template but getting an error…
sensors:
sun_left:
friendly_name: "Sun Left"
value_template: >-
{% if "(as_timestamp(state_attr('sun.sun', 'next_setting')) - as_timestamp(now())))" == "00:00") %}
{{ (as_timestamp(state_attr('sun.sun', 'next_rising')))| timestamp_custom('Sunrise in %-I:%M', 0) }}
{ % else % }
{{ (as_timestamp(state_attr('sun.sun', 'next_setting')) - as_timestamp(now()))| timestamp_custom('Sunset in %H:%M', 0) }}
{% endif %}
This is the error I get… tried multiple things… looked at brackets, quotes, etc…
Invalid config for [sensor.template]: invalid template (TemplateSyntaxError: unexpected ‘)’) for dictionary value @ data[‘sensors’][‘sun_left’][‘value_template’]. Got ‘{% if “(as_timestamp(state_attr('sun.sun', 'next_setting')) - as_timestamp(now())))” == “00:00”) %} {{ (as_timestamp(state_attr('sun.sun', 'next_rising')))| timestamp_custom('Sunrise in %-I:%M', 0) }} { % else % } {{ (as_timestamp(state_attr('sun.sun', 'next_setting')) - as_timestamp(now()))| timestamp_custom('Sunset in %H:%M', 0) }} {% endif %}’. (See ?, line ?).
Trying to find the error but it doesn’t seem to pop right out at me…
tom_l
May 28, 2022, 11:05am
2
You have an unmatched )
somewhere.
w35l3y
(w35l3y)
May 28, 2022, 11:24am
3
Red: remove these quotes
Purple: remove these parentheses
Blue: remove these spaces
{% if "((as_timestamp(state_attr('sun.sun', 'next_setting')) - as_timestamp(now())) == '00:00')" %}
{ % else % }
{% endif %}
Found a couple issues… this is working now.
Thank you!
w35l3y
(w35l3y)
May 28, 2022, 11:29am
5
These quotes turns the condition always true.
As a non-empty string is true.
Funny I was just writing about the return of the if statement being wrong… gives me the wrong return. So Thank you because that just fixed it…
{% if ((as_timestamp(state_attr('sun.sun', 'next_setting')) - as_timestamp(now())) == '00:00') %}
{% else %}
{% endif %}
(Taras)
May 28, 2022, 12:33pm
7
The first line of your template is an if
statement that checks if the result of a subtraction is equal to '00:00'
which is a string value.
The problem is that the result of the subtraction is a float value (like 43694.13402414322
) and it will never be equal to '00:00'
. That means that the if
statement will always evaluate to false
thereby never executing the Sunrise calculation.
That’s interesting… now trying to jam that into the if statement… LOL
Thank you!
123
(Taras)
May 28, 2022, 1:13pm
9
Alternative:
{% set setting = state_attr('sun.sun', 'next_setting') | as_datetime | as_local %}
{% set rising = state_attr('sun.sun', 'next_rising') | as_datetime | as_local %}
Sun{{ iif(rising < setting, 'rise', 'set') }} in {{ (iif(rising < setting, rising, setting) - now()).total_seconds() | timestamp_custom('%-I:%M', 0) }}
Copy-paste it into the Template Editor and confirm it produces the desired result. You’ll probably need to wait until after sunset today to confirm it correctly reports tomorrow’s sunrise.
123:
Works like a charm… Thank you… like making things compact and that’s easy to understand… I tend to complicate things… but not being a ‘programmer’ by education I’m learning as I go… can do javascript and php but this is new to me…
Thank you!!!
End result is working towards this →
not trying to take away from the templating exercise, you are aware you can have the frontend do a lot of this for you natively?
check things like:
- type: attribute
entity: sun.sun
attribute: next_rising
name: Sun next rising
icon: mdi:weather-sunset-up
format: time
- type: attribute
entity: sun.sun
attribute: next_setting
name: Sun next setting
icon: mdi:weather-sunset-down
format: relative
might not be what you can use in a markdown card like the template above, but still very nice to use:
and even the more-info shows what you’re after:
Yes and I’ll probably never really do anything but keep the templates I’m experimenting with to look back on… it’s all exercises to get to somewhere else
Thank you!!!
You must be using templates on those as well. So why not I’ll convert them directly to show what you’ve done… which is exactly what I want
