Hey guys, i am getting this weird message on the start of the logs (ini putty) in every restart: Error decoding json invalid character '\x1b' looking for beginning of value:
In white font, then it goes back to green to its normal routine.
I have looked up the utf char, and it decodes back as left arrow (e)
I copied my whole config folder to my pc and searched with windows Grep,'\x1b' is nowhere to be found but i find the back arrow (e) inside a .py file of a custom component i once tried to install but never worked (restore_states)
Anyway, i complete removed the residual files and any mention of this component in my configuration but i still get the error.
Any ideas?
core-ssh:~# hassio homeassistant restart
"result": "ok",
"data": {}
core-ssh:~# hassio homeassistant logs
Error decoding json invalid character '\x1b' looking for beginning of value: 2018-01-16 14:22:25 INFO (MainThread) [hbmqtt.broker] ...
I’m not sure what the character is, but I’d guess it’s just a minor issue with the hassio command line program’s parsing of the response and not something from your actual logs.
Edit: Just as an FYI, here appears to be the line in the code where that error gets printed.
