I’ve just installed the HACS integration, but after reboot I’ve reach this error in notifications tab:
Questo errore ha avuto origine da un'integrazione personalizzata.
Logger: homeassistant.config_entries
Source: custom_components/hacs/tasks/setup_frontend.py:6
Integration: HACS (documentation, issues)
First occurred: 21:51:41 (1 occurrences)
Last logged: 21:51:41
Error setting up entry for hacs
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 304, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/config/custom_components/hacs/__init__.py", line 39, in async_setup_entry
return await hacs_ui_setup(hass, config_entry)
File "/config/custom_components/hacs/operational/setup.py", line 94, in async_setup_entry
await _async_common_setup(hass)
File "/config/custom_components/hacs/operational/setup.py", line 50, in _async_common_setup
await hacs.tasks.async_load()
File "/config/custom_components/hacs/tasks/manager.py", line 43, in async_load
await asyncio.gather(*[_load_module(task) for task in task_modules])
File "/config/custom_components/hacs/tasks/manager.py", line 39, in _load_module
task_module = import_module(f"{__package__}.{module}")
File "/usr/local/lib/python3.9/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 850, in exec_module
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "/config/custom_components/hacs/tasks/setup_frontend.py", line 6, in <module>
from ..hacs_frontend import locate_dir
ModuleNotFoundError: No module named 'custom_components.hacs.hacs_frontend'
Has anyone a solution?
Thanks in advance
Alan Masutti
