I think we have the same problem. I’ve done pretty much the same thing as you and nothing seemed to run
Just ran systemctl start hassio-apparmor.service and that seemed to run something and I have a process called hassio-supervis running, however I have no user interface or anything else. Going to :8123 just gets me a time out still.
It is really easy getting Home Assistant working using a container on QNAP (although it is quite out of date). Getting HASSio to work though seems to be a lot tougher than it looks! Feeling like just stikcing with domoticz because it does work.
I’ve looked at this. The instructions don’t match my QNAPs setup. Can’t find a settings file and the config directory given by the file with more details just does not exist. Another false start
edit: and smiling again as I found the config files having been confused by two LXCs in the file path so moving on to the next bit
Well that looks as good as I am getting. I have the hassio-supervisor showing in ps -A.
That seems to do nothing. No UI is seen on :8123 and I can find nothing else that might make this work. I have to run the sysemctl command to get this much going, it does not start on boot up.
If I knew what SHOULD be running maybe I can take the next steps. I’m finding it hard to help myself here as the information differs wildly and different instructions seem to take me to different places. Others report success just with what I’m doing so can’t work out why I can’t.
If you read the script and the service files you can figure out what containers need to be running. Having a supervisor by itself doesn’t actually do anything. You need the home assistant docker image as well.
Good day to all.
I was able to successfully install hass.io on a qnap TS-235A.
I had the same issues but the upgraded qnap firmware to 4.4.1.1146 and it all worked.
One can do the same by the following steps:
Follow this instruction to install the rest of deps needed for hass.io - mainly the docker-ce - https://qiot.qnap.com/blog/en/2019/01/15/install-docker-x86-qnap-nas-lxc-container/
At this step it is important to make a bridge setting for the network (this will give a separate ip address to the ubuntu container) and attach z-wave hardware devices to ubuntu container
