Error installing Home Assistant Supervised on Ubuntu/Docker
Hi all,
I’ve installed Home Assistant Supervised on Ubuntu, with use of Docker. When i go to my IP it’s stuck on: Preparing Home Assistant. In Portainer i get the following error message:
2020/04/02 11:55:57 [error] 196#196: *13 open() “/usr/share/www/manifest.json” failed (2: No such file or directory), client: 192.168.2.11, server: , request: “GET /manifest.json HTTP/1.1”, host: “192.168.x.x:8123”, referrer: “http://192.168.x.x:8123/
Can anyone help me with this issue?
Kind regards
SOLVED! Disk was full.
Do you have any tutorial reference link for installing the home assistant supervised on Ubuntu? Thanks
Do the same as the following: https://www.youtube.com/watch?v=ekVfLXnoM7k only when you need to download the home assistant file, use the link from the official website.
Actually i also followed that tutorial. But when i finished and check the container on my docker, i cant find any home assistant container.
any idea how to solve? Thanks.
i followed that step by step, but still can’t find the home assistant container in the docker. I have no idea how could it happen.
