I am having problems installing home assistant. i can access comand line no problem but i get this error accessing web GUI
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[10:58:03] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[10:58:03] INFO: Starting local supervisor watchdog...
23-04-04 10:58:14 INFO (MainThread) [__main__] Initializing Supervisor setup
23-04-04 10:58:14 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
23-04-04 10:58:15 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi3-64
23-04-04 10:58:15 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2023.12.0
23-04-04 10:58:15 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-04-04 10:58:15 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
23-04-04 10:58:15 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 10:58:15 INFO (MainThread) [__main__] Setting up Supervisor
23-04-04 10:58:20 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-04-04 10:58:21 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-04-04 10:58:21 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-04-04 10:58:21 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-04-04 10:58:21 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-04-04 10:58:21 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-04-04 10:58:21 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-04-04 10:58:21 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-04-04 10:58:21 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-04-04 10:58:21 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-04-04 10:58:21 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-04-04 10:58:22 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 10:58:22 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 10:58:22 WARNING (SyncWorker_1) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
23-04-04 10:58:22 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-04-04 10:58:28 WARNING (MainThread) [supervisor.utils.whoami] Can't fetch Whoami data: Cannot connect to host services.home-assistant.io:443 ssl:default [Try again]
23-04-04 10:58:28 WARNING (MainThread) [supervisor.core] Can't adjust Time/Date settings: Can't fetch Whoami data: Cannot connect to host services.home-assistant.io:443 ssl:default [Try again]
23-04-04 10:58:28 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-04-04 10:58:33 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 10:58:33 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: [<AwesomeVersion CalVer '2023.11.0'>]
23-04-04 10:58:33 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0
23-04-04 10:58:33 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-04-04 10:58:35 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0 - 172.30.32.5
23-04-04 10:58:35 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2023.06.2'>]
23-04-04 10:58:35 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
23-04-04 10:58:35 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-04-04 10:58:39 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
23-04-04 10:58:39 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-04-04 10:58:44 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2023.12.0'>]
23-04-04 10:58:44 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
23-04-04 10:58:44 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-04-04 10:58:46 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
23-04-04 10:58:47 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-04-04 10:58:47 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
23-04-04 10:58:47 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-04-04 10:58:50 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0 - 172.30.32.6
23-04-04 10:58:50 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2023.06.2'>]
23-04-04 10:58:50 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2
23-04-04 10:58:50 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-04-04 10:58:53 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2 - Host
23-04-04 10:58:53 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-04-04 10:58:53 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/raspberrypi3-64-homeassistant
23-04-04 10:58:53 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant found.
23-04-04 10:58:53 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
23-04-04 10:58:53 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
23-04-04 10:58:53 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-04-04 10:58:53 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-04-04 10:58:55 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
23-04-04 10:58:55 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.4 / BootSlot A
23-04-04 10:58:57 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 10:58:57 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant
23-04-04 10:58:59 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 10:58:59 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant
23-04-04 10:59:00 WARNING (MainThread) [supervisor.jobs] 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 10:59:00 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/hassio-addons/repository due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 10:59:00 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / a0d7b954
23-04-04 10:59:00 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
23-04-04 10:59:00 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/esphome/home-assistant-addon due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 10:59:00 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / 5c53de3b
23-04-04 10:59:00 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
23-04-04 10:59:00 ERROR (MainThread) [supervisor.store] Can't add repository core due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 10:59:00 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / core
23-04-04 10:59:00 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / core
23-04-04 10:59:00 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 10:59:00 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
23-04-04 10:59:00 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
23-04-04 10:59:01 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-04-04 10:59:01 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-04-04 10:59:01 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-04-04 10:59:01 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
23-04-04 10:59:01 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-04-04 10:59:01 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-04-04 10:59:01 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 10:59:01 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
23-04-04 10:59:01 INFO (MainThread) [__main__] Running Supervisor
23-04-04 10:59:01 INFO (SyncWorker_2) [supervisor.docker.manager] Starting homeassistant
23-04-04 10:59:01 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-04-04 10:59:01 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
23-04-04 10:59:01 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
23-04-04 10:59:01 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
23-04-04 10:59:01 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
23-04-04 10:59:01 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
23-04-04 10:59:01 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-04-04 10:59:01 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-04-04 10:59:01 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-04-04 10:59:01 INFO (MainThread) [supervisor.host.info] Updating local host information
23-04-04 10:59:01 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-04-04 10:59:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-04-04 10:59:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-04-04 10:59:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-04-04 10:59:02 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-04-04 10:59:03 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 10:59:03 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 10:59:04 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 10:59:04 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-04-04 10:59:06 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 10:59:06 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-04-04 10:59:06 INFO (MainThread) [supervisor.jobs] 'CheckDNSServer.run_check' blocked from execution, no supervisor internet connection
23-04-04 10:59:06 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-04-04 10:59:06 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-04-04 10:59:06 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-04-04 10:59:07 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-04-04 10:59:12 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6.run_check' blocked from execution, no supervisor internet connection
23-04-04 10:59:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
23-04-04 10:59:12 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
23-04-04 10:59:12 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
23-04-04 10:59:12 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-04-04 10:59:17 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
23-04-04 10:59:17 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-04-04 10:59:17 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-04-04 10:59:18 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 10:59:18 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
23-04-04 10:59:23 WARNING (MainThread) [supervisor.jobs] 'FixupStoreExecuteReload.process_fixup' blocked from execution, no supervisor internet connection
23-04-04 10:59:23 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-04-04 10:59:41 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 10:59:41 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
[17:17:48] INFO: Using udev information from host
[17:17:49] INFO: Starting local supervisor watchdog...
24-01-13 17:17:59 INFO (MainThread) [__main__] Initializing Supervisor setup
24-01-13 17:17:59 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi3-64
24-01-13 17:17:59 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2023.12.0
24-01-13 17:17:59 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-01-13 17:17:59 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-01-13 17:17:59 INFO (MainThread) [__main__] Setting up Supervisor
24-01-13 17:18:00 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-01-13 17:18:00 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-01-13 17:18:00 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-01-13 17:18:00 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-01-13 17:18:00 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-01-13 17:18:00 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-01-13 17:18:00 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-01-13 17:18:00 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-01-13 17:18:00 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-01-13 17:18:00 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-01-13 17:18:00 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-01-13 17:18:01 INFO (MainThread) [supervisor.host.services] Updating service information
24-01-13 17:18:01 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-01-13 17:18:01 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-01-13 17:18:03 INFO (MainThread) [supervisor.host.network] Updating local network information
24-01-13 17:18:03 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-01-13 18:18:03 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-01-13 18:18:03 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-01-13 18:18:03 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0
24-01-13 18:18:03 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-01-13 18:18:03 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
24-01-13 18:18:06 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0 - 172.30.32.5
24-01-13 18:18:06 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
24-01-13 18:18:06 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-01-13 18:18:06 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
24-01-13 18:18:10 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
24-01-13 18:18:10 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-01-13 18:18:10 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
24-01-13 18:18:10 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
24-01-13 18:18:10 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application
24-01-13 18:18:14 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
24-01-13 18:18:14 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
24-01-13 18:18:14 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2
24-01-13 18:18:14 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
24-01-13 18:18:14 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application
24-01-13 18:18:17 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2 - Host
24-01-13 18:18:17 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-01-13 18:18:17 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
24-01-13 18:18:17 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-01-13 18:18:17 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant
24-01-13 18:18:19 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.4 / BootSlot A
24-01-13 18:18:19 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
24-01-13 18:18:19 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
24-01-13 18:18:19 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
24-01-13 18:18:23 INFO (MainThread) [supervisor.store] Loading add-ons from store: 78 all - 78 new - 0 remove
24-01-13 18:18:23 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-01-13 18:18:23 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-01-13 18:18:23 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-01-13 18:18:23 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-01-13 18:18:23 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-01-13 18:18:23 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-01-13 18:18:23 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-01-13 18:18:23 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-01-13 18:18:23 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
24-01-13 18:18:23 INFO (MainThread) [__main__] Running Supervisor
24-01-13 18:18:23 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-01-13 18:18:23 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
24-01-13 18:18:23 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
24-01-13 18:18:23 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
24-01-13 18:18:23 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
24-01-13 18:18:23 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
24-01-13 18:18:23 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
24-01-13 18:18:23 INFO (MainThread) [supervisor.core] Supervisor is up and running
24-01-13 18:18:23 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
24-01-13 18:18:23 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2024.1.3
24-01-13 18:18:23 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant with tag 2024.1.3.
24-01-13 18:18:23 INFO (MainThread) [supervisor.host.info] Updating local host information
24-01-13 18:18:23 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-01-13 18:18:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-01-13 18:18:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-01-13 18:18:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-01-13 18:18:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-01-13 18:18:23 INFO (MainThread) [supervisor.host.services] Updating service information
24-01-13 18:18:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-01-13 18:18:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-01-13 18:18:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-01-13 18:18:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-01-13 18:18:23 INFO (MainThread) [supervisor.host.network] Updating local network information
24-01-13 18:18:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-01-13 18:18:23 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
24-01-13 18:18:24 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
24-01-13 18:18:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-01-13 18:18:24 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-01-13 18:18:24 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-01-13 18:18:24 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-01-13 18:18:24 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-01-13 18:18:25 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-01-13 18:18:25 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-01-13 18:18:25 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
[17:27:39] INFO: Using udev information from host
[17:27:39] INFO: Starting local supervisor watchdog...
24-01-13 17:27:50 INFO (MainThread) [__main__] Initializing Supervisor setup
24-01-13 18:27:50 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi3-64
24-01-13 18:27:50 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2023.12.0
24-01-13 18:27:50 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-01-13 18:27:50 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-01-13 18:27:50 INFO (MainThread) [__main__] Setting up Supervisor
24-01-13 18:27:51 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-01-13 18:27:51 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-01-13 18:27:51 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-01-13 18:27:51 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-01-13 18:27:51 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-01-13 18:27:51 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-01-13 18:27:51 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-01-13 18:27:51 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-01-13 18:27:51 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-01-13 18:27:51 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-01-13 18:27:51 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-01-13 18:27:52 INFO (MainThread) [supervisor.host.services] Updating service information
24-01-13 18:27:52 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-01-13 18:27:52 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-01-13 18:27:54 INFO (MainThread) [supervisor.host.network] Updating local network information
24-01-13 18:27:54 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-01-13 18:27:54 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-01-13 18:27:54 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-01-13 18:27:54 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0
24-01-13 18:27:54 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-01-13 18:27:54 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
24-01-13 18:27:57 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0 - 172.30.32.5
24-01-13 18:27:57 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
24-01-13 18:27:57 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-01-13 18:27:57 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
24-01-13 18:28:01 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
24-01-13 18:28:01 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-01-13 18:28:01 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
24-01-13 18:28:01 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
24-01-13 18:28:01 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application
24-01-13 18:28:05 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
24-01-13 18:28:05 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
24-01-13 18:28:05 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2
24-01-13 18:28:05 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
24-01-13 18:28:05 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application
24-01-13 18:28:08 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2 - Host
24-01-13 18:28:08 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-01-13 18:28:08 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
24-01-13 18:28:08 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-01-13 18:28:09 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
24-01-13 18:28:10 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.4 / BootSlot A
24-01-13 18:28:12 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
24-01-13 18:28:12 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
24-01-13 18:28:12 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
24-01-13 18:28:14 INFO (MainThread) [supervisor.store] Loading add-ons from store: 78 all - 78 new - 0 remove
24-01-13 18:28:14 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-01-13 18:28:14 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-01-13 18:28:14 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-01-13 18:28:14 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-01-13 18:28:14 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
24-01-13 18:28:14 INFO (MainThread) [__main__] Running Supervisor
24-01-13 18:28:14 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-01-13 18:28:14 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
24-01-13 18:28:14 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
24-01-13 18:28:14 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
24-01-13 18:28:14 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
24-01-13 18:28:14 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
24-01-13 18:28:14 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
24-01-13 18:28:14 INFO (MainThread) [supervisor.core] Supervisor is up and running
24-01-13 18:28:14 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
24-01-13 18:28:14 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2024.1.3
24-01-13 18:28:14 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant with tag 2024.1.3.
24-01-13 18:28:14 INFO (MainThread) [supervisor.host.info] Updating local host information
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-01-13 18:28:14 INFO (MainThread) [supervisor.host.services] Updating service information
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-01-13 18:28:14 INFO (MainThread) [supervisor.host.network] Updating local network information
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-01-13 18:28:14 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-01-13 18:28:15 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-01-13 18:28:15 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-01-13 18:28:15 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-01-13 18:28:17 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-01-13 18:28:17 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-01-13 18:28:17 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
24-01-13 18:40:12 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/004 - None
24-01-13 18:40:12 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/input/event0 - /dev/input/by-id/usb-SIGMACHIP_USB_Keyboard-event-kbd
24-01-13 18:40:12 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/hidraw0 - None
24-01-13 18:40:12 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/input/event1 - /dev/input/by-id/usb-SIGMACHIP_USB_Keyboard-event-if01
24-01-13 18:40:12 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/input/event2 - /dev/input/by-id/usb-SIGMACHIP_USB_Keyboard-event-if01
24-01-13 18:40:12 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/hidraw1 - None
24-01-13 18:40:33 INFO (MainThread) [supervisor.plugins.dns] Restarting CoreDNS plugin
24-01-13 18:40:33 INFO (SyncWorker_2) [supervisor.docker.manager] Restarting hassio_dns
[17:50:29] INFO: Using udev information from host
[17:50:29] INFO: Starting local supervisor watchdog...
24-01-13 17:50:40 INFO (MainThread) [__main__] Initializing Supervisor setup
24-01-13 18:50:40 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi3-64
24-01-13 18:50:40 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2023.12.0
24-01-13 18:50:41 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-01-13 18:50:41 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-01-13 18:50:41 INFO (MainThread) [__main__] Setting up Supervisor
24-01-13 18:50:41 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-01-13 18:50:41 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-01-13 18:50:41 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-01-13 18:50:41 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-01-13 18:50:41 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-01-13 18:50:41 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-01-13 18:50:41 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-01-13 18:50:41 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-01-13 18:50:41 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-01-13 18:50:41 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-01-13 18:50:41 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-01-13 18:50:43 INFO (MainThread) [supervisor.host.services] Updating service information
24-01-13 18:50:43 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-01-13 18:50:43 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-01-13 18:50:44 INFO (MainThread) [supervisor.host.network] Updating local network information
24-01-13 18:50:44 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-01-13 18:50:44 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-01-13 18:50:44 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-01-13 18:50:44 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0
24-01-13 18:50:45 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-01-13 18:50:45 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
24-01-13 18:50:47 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0 - 172.30.32.5
24-01-13 18:50:48 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
24-01-13 18:50:48 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-01-13 18:50:48 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
24-01-13 18:50:52 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
24-01-13 18:50:52 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-01-13 18:50:52 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
24-01-13 18:50:52 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
24-01-13 18:50:52 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_audio application
24-01-13 18:50:56 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
24-01-13 18:50:56 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
24-01-13 18:50:56 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2
24-01-13 18:50:56 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
24-01-13 18:50:56 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application
24-01-13 18:50:59 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2 - Host
24-01-13 18:50:59 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-01-13 18:50:59 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
24-01-13 18:50:59 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-01-13 18:50:59 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant
24-01-13 18:51:01 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.4 / BootSlot A
24-01-13 18:51:03 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
24-01-13 18:51:03 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
24-01-13 18:51:03 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
24-01-13 18:51:04 INFO (MainThread) [supervisor.store] Loading add-ons from store: 78 all - 78 new - 0 remove
24-01-13 18:51:04 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-01-13 18:51:04 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-01-13 18:51:04 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-01-13 18:51:04 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-01-13 18:51:04 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-01-13 18:51:04 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-01-13 18:51:04 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-01-13 18:51:04 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-01-13 18:51:05 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-01-13 18:51:05 INFO (MainThread) [__main__] Running Supervisor
24-01-13 18:51:05 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-01-13 18:51:05 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
24-01-13 18:51:05 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
24-01-13 18:51:05 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
24-01-13 18:51:05 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
24-01-13 18:51:05 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
24-01-13 18:51:05 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
24-01-13 18:51:05 INFO (MainThread) [supervisor.core] Supervisor is up and running
24-01-13 18:51:05 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
24-01-13 18:51:05 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2024.1.3
24-01-13 18:51:05 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant with tag 2024.1.3.
24-01-13 18:51:05 INFO (MainThread) [supervisor.host.info] Updating local host information
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-01-13 18:51:05 INFO (MainThread) [supervisor.host.services] Updating service information
24-01-13 18:51:05 INFO (MainThread) [supervisor.host.network] Updating local network information
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-01-13 18:51:05 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-01-13 18:51:06 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-01-13 18:51:06 WARNING (SyncWorker_1) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-01-13 18:51:06 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-01-13 18:51:08 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-01-13 18:51:08 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-01-13 18:51:08 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
