Error installing in docker
Trying to install Home Assistant via Docker Compose, but I get this Error.
ERROR: The Compose file './docker-compose.yaml' is invalid because:
'homeassistant' does not match any of the regexes: '^x-'
You might be seeing this error because you're using the wrong Compose file version. Either specify a supported version (e.g "2.2" or "3.3") and place your service definitions under the `services` key, or omit the `version` key and place your service definitions at the root of the file to use version 1.
This is what I have in my docker-compose.yaml
version: '3.0'
services:
homeassistant:
    container_name: homeassistant
    image: "ghcr.io/home-assistant/home-assistant:stable"
    volumes:
      - /opt/homeassistant/config:/config
      - /etc/localtime:/etc/localtime:ro
    restart: unless-stopped
Error appears when I run
docker-compose up -d
I think your version should be 3.3. Indentation also looks off. This should work
version: '3.3'
services:
    home-assistant:
        volumes:
            - '/opt/homeassistant/config:/config'
        environment:
            - TZ=America/New_York
        network_mode: host
        image: 'ghcr.io/home-assistant/home-assistant:stable'
Replace with your time zone from this list
Thx 4 reply
Same error with your suggestion.
I followed this Linux - Home Assistant
Must be something I’m missing. Installed portainer the same way without any problems
My bad
Had a wrong indention in one line.
I had the same error and it took me a while to realise I had to indent the word homeassistant one step and it all worked
