Error installing TensorFlow
Today I did a big clean-up at my server and somehow I broke my Tensorflow isntance…
And playing the whole day around to get it up and running but without any result.
I run Home-Assistant in a docker container, and tried to install Tensorflow via ->
docker exec -it home-assistant /bin/bash
and then within the container ->
pip3 install tensorflow==1.15.0
All the other needed files are in my config/tensorflow/ directory
Home Assistant is providing the following error.
Error while setting up platform tensorflow
  File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
    return fut.result()
  File "/usr/src/app/homeassistant/components/tensorflow/image_processing.py", line 93, in setup_platform
    import tensorflow as tf # noqa
  File "/usr/local/lib/python3.7/site-packages/tensorflow/__init__.py", line 99, in <module>
    from tensorflow_core import *
  File "/usr/local/lib/python3.7/site-packages/tensorflow_core/__init__.py", line 28, in <module>
    from tensorflow.python import pywrap_tensorflow  # pylint: disable=unused-import
  File "<frozen importlib._bootstrap>", line 1019, in _handle_fromlist
  File "/usr/local/lib/python3.7/site-packages/tensorflow/__init__.py", line 50, in __getattr__
    module = self._load()
  File "/usr/local/lib/python3.7/site-packages/tensorflow/__init__.py", line 44, in _load
    module = _importlib.import_module(self.__name__)
  File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "/usr/local/lib/python3.7/site-packages/tensorflow_core/python/__init__.py", line 63, in <module>
    from tensorflow.python.framework.framework_lib import *  # pylint: disable=redefined-builtin
  File "/usr/local/lib/python3.7/site-packages/tensorflow_core/python/framework/framework_lib.py", line 52, in <module>
    from tensorflow.python.framework.importer import import_graph_def
  File "/usr/local/lib/python3.7/site-packages/tensorflow_core/python/framework/importer.py", line 28, in <module>
    from tensorflow.python.framework import function
  File "/usr/local/lib/python3.7/site-packages/tensorflow_core/python/framework/function.py", line 36, in <module>
    from tensorflow.python.ops import array_ops
  File "/usr/local/lib/python3.7/site-packages/tensorflow_core/python/ops/array_ops.py", line 3090, in <module>
    @ops.RegisterGradient("FakeQuantWithMinMaxArgs")
  File "/usr/local/lib/python3.7/site-packages/tensorflow_core/python/framework/ops.py", line 2486, in __call__
    _gradient_registry.register(f, self._op_type)
  File "/usr/local/lib/python3.7/site-packages/tensorflow_core/python/framework/registry.py", line 63, in register
    logging.vlog(1, "Registering %s (%s) in %s.", name, candidate, self._name)
  File "/usr/local/lib/python3.7/site-packages/tensorflow_core/python/platform/tf_logging.py", line 200, in vlog
    get_logger().log(level, msg, *args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/tensorflow_core/python/platform/tf_logging.py", line 104, in get_logger
    if not _logging.getLogger().handlers:
TypeError: get_logger() missing 1 required positional argument: 'name'
